Thread: Fuel Filter
Page 2 of 2 FirstFirst 12
Showing results 21 to 23 of 23
  1. #21
    and, also, instead of using a bucket, first i just let as much gasoline drain as possible whlie still holding the fuel pump module somewhat inside the tank (but out of the gas).
    and then, i disassembled the module on the ground, covered with a large heavy-duty trashbag and layered with shop paper towels to absorb gasoline.
  2. #22
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    and do it with a emptyish fuel tank, i did my fuel pump the hardest part is getting the dam top back on and the pump sitting right
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
  3. #23
    Thanks for the advice guys, ill let you know how it comes out when i get around to it.
