Thread: MKO's AWD/Turbo/DOHC/5 Speed Project
Page 10 of 53 FirstFirst ... 6789101112131420 ... LastLast
Showing results 181 to 200 of 1043
  1. #181
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    My blue shitz came in.
    Now I have everything for the swap. Cant wait!!
    On a side note:
    I came across something that might help you 96-98 guys who want to do the DOHC swap with 1g head. Its a cool thing I got off 97 Sonata with 4g63.
    As you know you the 1g intake manifold doesnt have the MAP sensor since its not OBD2 compliant and many of you have avoided it for that reason only. Theres an adapter sold, but first its expensive and second it doesnt look too good. Well heres the solution:
    As I said it came off 97 Sonata and its a part made by Mitsubishi:
    Excuse my drawing on that photo. it was for a some knuckle head on another forum who was trying to tell me that 2g have MAFs not MAPs.
    So installation is simple as this: the plug is P'n'P and all you need to do is to source a vacuum to the hose.Done!!
    I got this MAP of the j/y for $1.50. I told them it was a solenoid.
    Build Thread
  2. #182
    ^ so would that do away with the karmon vortex?
  3. #183
    TGC Regular phizzalot's Avatar
    04-25-2007
    Orlando/Ft. Luderdale ex {phizz2k}
    727
    So there's a hole and screws mount to install that map on a 1g intake? What is installed there originally and why couldn't you reuse a map from the galant?
  4. #184
    09-20-2007
    Sea Isle city, NJ
    4,098
    nope, sorry theres no such a hole for a MAP on 1g intake mani and since theres no hole you have to buy the adapter which is twenty some dollars or use the sonata MAP sensor
    Build Thread
  5. #185
    09-20-2007
    Sea Isle city, NJ
    4,098
    Just bought this:
    http://cgi.ebay.com/ebaymotors/Magna...item58856af38f
    I was debating between the muffler and 12'' dual slim fans. Now I cant wait to install it.
    Build Thread
  6. #186
    12-17-2004
    Louisville, KY
    4,327
    there's no MAP sensor on the 1g or 2g or 3g or 4g
    its called a MDP
    manifold differential pressure sensor.
    all it does it verify EGR function. by looking for a Difference in Manifold Pressure when the egr is open or closed.
  7. #187
    09-20-2007
    Sea Isle city, NJ
    4,098
    finally arrived. i love it. magnaflow FTW
    Build Thread
  8. #188
    08-13-2008
    Waterbury, CT
    3,331
    just noticed something.. now the ARPs you got are main studs for the crank and thats what you were missing for the swap?
    my ARP head studs are part#207-4203 and my main studs are your part number i see there on the box.
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  9. #189
    09-20-2007
    Sea Isle city, NJ
    4,098
    Snagged this brand new 90 deg 3'' bend from the junkyard for $5. It was off brand new pacesetter exhaust. This will be my new full 3'' downpipe and full 3'' turbo back exhaust
    Build Thread
  10. #190
    08-13-2008
    Waterbury, CT
    3,331
    hey.. did those ARPs end up being the right size?
    2014 Lancer Evo GSR
  11. #191
    09-20-2007
    Sea Isle city, NJ
    4,098
    nope. they are 10mm main studs. Its all ok i got them really cheap, and Ill find a use for the some day
    Build Thread
  12. #192
    08-13-2008
    Waterbury, CT
    3,331
    damn.. when you build a new motor it will come in handy. i got my ARPs on ebay from titan motor sports( the supra shop) for like 88 bucks if you havent found them cheaper
    2014 Lancer Evo GSR
  13. #193
    09-20-2007
    Sea Isle city, NJ
    4,098
    yeap, just got them for 89 shipped
    Now I need ARP rod bolts
    Build Thread
  14. #194
    08-13-2008
    Waterbury, CT
    3,331
    if you buy eagle or manleys and a couple others they come with ARP rod bolts. what are the future plans here?
    2014 Lancer Evo GSR
  15. #195
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by Galanttuner10 View Post
    Well the plan is:
    8g crank knife edged and micro polished
    Eagle Rods
    Manley or Wiseco pistons /still debating on the CR 8.5 or 9 to 1/
    ACL bearings
    ARP hardware kit
    OEM Gasket
    The cheap version of it:
    my 7g crank
    Evo8-9 Rods
    ACL bearings
    ARP hardware kit
    OEM Gasket
    In addition I have a LSD transmission, still have to do the balance shaft deletion and buy a 6 bolt crank pulley. i read they are 2-3 pound lighter
    on a side note, Ive decided not to take advantage of the features the Cyclone manifold offers. As Im writing im taking it apart for a porting job and removing the butterflies. It will be used as 1g manifold. Need to figure out how to make the EGR functional
    Build Thread
  16. #196
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Are you running a 1g head? If so those butterflies will really help with spool and low end. Not that a 2.4 really needs much help on spool-up.
    What are your reasons for not running it with the valves?
  17. #197
    09-20-2007
    Sea Isle city, NJ
    4,098
    Quote Originally Posted by eclipsh View Post
    Yeap, thats the reason. 2.4 gives you the 400-500 lower spool up, so if a 2.0L with 1g head and 1g intake mani can run fine then theres no reason a 2.4 with 1g head and open Cyclone shouldnt be fine.
    Build Thread
  18. #198
    09-20-2007
    Sea Isle city, NJ
    4,098
    Magnaflow FTW
    Build Thread
  19. #199
    nIIce!! thats what i call universalllll
  20. #200
    09-20-2007
    Sea Isle city, NJ
    4,098
    Few more things came in the mail:
    Header wrap
    you know what it is
    Punishment Racing J-pipe
    Picked up Lexus ES 300 projector fogs.
    3'' flex pipe
    Heat reflective intake wrap
    Bought a Big 16g off Galant vr4.org and its coming this week
    Peano /Matt/ is sending me a proportioning valve for the brakes
    Build Thread
