The galant ES comes with steelies with hub caps GTZ galants come with these:
I have my eye on a nice 8g galant and I want to know which rims that particular model bring, BTW is 99 ES model, the car have ones like with many spokes, umm like 8 i guess not sure, anyways thanks in advance and please place some pics...
4g64T 5spd
EDIT:
^^^ well ok so you know the only wheels that come stock on a 8G are those posted above and below VVV but no 8 spoke wheels
4g64T 5spd
didn't these wheels come stock on a 99 8g also??
my 1999 ES V6 came with hubcaps: The 10 spoke star pattern
thaks a lot, so now im for sure that the ones that I see are from another car...maybe an old mirage...what type of rims do u recomend, not to many big, just a clean look, thanks
Evo rims are 17 and look really clean also eclipse wheels.
4g64T 5spd
lol...how many times you edit that post, omega phx??
jejeje thanks a lot, evo rims would look awsome but eclipse are cheaper rigth?
LOL like 3 or 4 times lol
Not really you just need to look for a deal you can check on http://www.evolutionm.net/ or craiglist
4g64T 5spd
niiice that price sounds like a bargain, thanks a lot for the inflo I would get my time in that website...
Will these fit without any hub centric rings/spacers etc? (the evo rims in your sig) Which generation Evo is it? Otherwise, I was looking at Eclipse wheels from 2007 17inch ones. Do I need any rings/spacers for those? Which lugs would you recommend?
The lug pattern on a G is 114.3mm I believe, 5 lug. If the rims are off a Mitsu they should fit no problems. I had 18" rims off an 07 eclipse and had to get smaller tires otherwise they hit the suspension, looks better without the balloons too. Not sure about the 17" rims, but you might not have to get low profile tires to make it fit.
If your talking about njjfudges rims they look like they are off an Evo 8.
1991 Jeep Comanche (SOLD)
2002 Honda Accord EX (DAILY)
1998 Eclipse GST (PROJECT)
Mitsubishi to Mitsubishi (EVO/Eclipse/Outlander...etc to Galant) they'll bolt right up without hubcentric rings. That said, the tires on a 2007 4th Generation Eclipse are too large for 2003 and OLDER Galants. 2004 - Present Mitsubishi Galant's will use identical size tires and wheels.
