HATERS! .. :D
you should love it.
only thing ive heard of going wrong with the 9g is cat. converters .. which are easy to replace. and if youre into performance mods. throw in a high flow and you wont have to worry about it.
and im not sure if the 2.4 has the same sensors as the 3.8 but if it does i can set you up with an ecu reflash that will take care of any pesky lights and make the car run a whole lot better.
