Alrighty, on the 03 transmission there are 2 sensors on the auto transmission. The output shaft speed sensor, and the input shaft speed sensor. So between the two I would assume that the wires needed that run to c-17 would be there.
few more pics :)
(Thanks for selling me the speed sensor Cali :D )
wires (black_blue, black, and black_yellow)
the same diagram from Figure 3. (Black_Yellow is for pin 3, Black_Blue is for pin 4, & ground is pin 2)
run1206's Rear Disc Tutorial
i gotta quick question..... what if you put a 99-01 guage cluster in a 02-03 model, would you still need to run the extra wires? or would the speedometer work like nothing was there....
isnt it possible to run wires from the black inhibitor plug to the manual trannys speed sensor? the same plug used to start the car?
Well I tried this out with no luck today. I took some pics of what I connected to, maybe I was just hooking up to the wrong stuff. Ill post the pics tomorrow.
anything new on this?
Fully Built 4G63
HKS 272
ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
there's a big discussion on WhiteGalant's thread "Wired up the speedo and..."
i wired it up to what i thought was pin 3 & 4 but the speedo only works when the gas tank is less than 3/4 full. Odd, i know...
still trying other combinations but that's the only way i can get my speedo to work.
Kind of un-related but... Will the 99-01 guage cluster hook right up to the 02-03 with no modification? Or will there have to be some kind of mod?
lol yes it will fit no problem, plug and play, so to say... if you want to keep your door light when you open your door, you need to swap out the circut board on the back, and also your odometer, or you will have like me, i open my door, and my gas light comes on lol
