Another view:
Well ive been collecting information for some time and I share this for everyone's knowledge.
Ive made the transition from Evo 8 ECU to 94-95 galant ECU harness, so we too can enjoy all flashing and tuning capabilities. It took some time, this is just a "prototype" conversion, I still need to figure out some of the AC pins. It is done from a GS model point of view - already running coil packs and knock sensor. I can do another one from S,ES and LS - running distributor, but that will be later.
Evo 8 pinout
94-95 7g pinout
Evo to Galant conversion
Now the best part: Since the Galant has 3 ECU plugs which are actually the same as the plugs of the Evo 8 ECU, and if the smallest plug (yellow) of the EVO ECU want there all pins would have matched. Still have to swap a few pins, but thats no biggie.
For Red and Blue plugs all numbers match, but still a couple of pins need to be added or swapped. If yellow wasnt there the green 71 for the Evo ECU would have matched the green 51 for the Galant ECU. So the entire plug except for the pin 73 MDP sensor and pin 79 Data link connector are identical (p'n'p)
Another view:
I can work on 96-98 Models if interested
Nice.
Ugh... MKo you are a god when it comes to figuring this shit out... We can experiment on my G if you want.. We need to get working on it!! I want it running by mid summer!!!!
do one on the 96 as i was looking into this even though i have a 2g ecu now.
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
Sweet..BTW, I thought you were going to use the GS ECU.
1994 GS FYI
DSM/CSM Manuals
Excellent Work MKO...I believe there was a 95-98 evo ecu swap done by tom back in the day but it would be cool to see u do one..
he had 2g ecu
he said he upgraded to an evo ecu...
i got diagrams on how to go from a 2G ecu to a evo 8 ecu
The color-coated pins indicate those that need to be swapped/changed/disconnected:
Swap pins 8 and 22
Connect pin 32 from the EVO ECU to pin 20 on the vehicle wiring for the eclipse
Connect pin 34 from the EVO ECU to pin 21 on the vehicle wiring for the eclipse
Disconnect pin 87
Disconnect pin 42
Ok, here it is.
Evo 8 ECU pinout
96-98 Galant ECU pinout
Evo8 to 96-98 Galant ECU conversion
A very weird change of pins. The 96-98 ECU pretty much kept the same configuration as 94-95, but it has an extra plug (the smallest one). Even the pin numbers are switched
Another view of the conversion:
A bit info on OBD plugs used for flashing.
Found this on DSMTuners. Not my creation, but to keep everything in one thread I post it here. Big thumbs up for whoever did it.
1g ECU pinout
and the difference from 94 Galant ECU pinout. Looks very similar, ut plugs are switched from left to right
Again Evo 8 ECU pinout
1g DSM to Evo8 conversion
There is a small connector next to the DLC that resemble the ecu flash plug on the GS, not sure about the other models.
1994 GS FYI
DSM/CSM Manuals
wow how did i miss this? sweet find MKO.
Just wanted to Bump this and say Awesome Work MKO,
I used this on a gs build and so far the ecu is getting power and it looks like everything will work.
Iam unable to flash the ecu though, I think it has to do with Evo/pin79, You specify "add" but did not know where the other end of the wire was to connect too.
After a bit of research I found that Evo/pin79 should be attached to pin26 on the Diagnostic Port.
Also Evo/pin62 should be connected to obd connector pin7
I haven't tried this yet but I will hopefully be able to test read/Write with Ecu Flash this weekend and post some results.
I got these pics and information from http://evoecu.logic.net/
im glad i was able to help
So who wants to do this to my GS to convert it to speed density?
Armandotech Its a bit of work but if you start a thread with a plan of how you are going to execute, I am sure people will chime in.
Havn't been back to update in sometime but the flashing works.... No start yet, just a bunch of sputtering and pops :(. Will be going over my wiring.
