The error code for vehicle speed sensor is 24. If you dont have it then most likely the gauge itself went bad or there faulty contacts on the back of the cluster where it goes in the harness connector. Or the screws that hold the gauge in place are also used for power supply and signal supply, so pop the cluster and inspect it. The screws are in the back of the cluster, theres like flexible circuit board that glued to the plastic. Also if you have installed the gauge overlays then there might be a problem with the needle itself - it might be sticking or it might have come off the shaft. Play with it and worst case scenario get a new cluster from the j/y. no more 150mph speedo for you
