if a v6 and you dropped, its normal, i ve been ldriving my G for more tha 6 years like that
and it feel bad, this one of the reason that i dont want to keep my G when i get another car.
I'm sure there's dozens of similar threads, but I did search for a while and could still use some help.
At nearly any speed, I feel a moderate vibration through the gas pedal and an accompanying hum. It doesn't sound to me like it's coming from either side really or anything engine-related; just seems to come from the front center almost. I jacked up the front and tried to wiggle the wheels and there seems to be no play at all on either side. I spun the wheels and didn't notice any noise that seemed irregular to me. The CV boots are in tact - how can I tell if it might be my axles?
This seems to have started soon after I heard a strange sound like I had run over something and didn't see anything in the road behind me. There are no other drivability issues.
Any help is appreciated!
JDM front covension Old style vr4,18"axis black seven mod,clifford alarm,egr rear window visor,kenwood unit 7"screen DVD,two tones paint job,3G strut bar , HID's.
I also noticed today that the noise/vibe is present only while going straight or turning right. It is absent during even slight left turns. I also swapped to a different set of wheels so it is not wheel or tire related.
I used to think the same thing about my car. Thought it was normal, just because it was droppped, etc.
A few months ago when I ditched my auto trans and went 5-speed, I replaced the front hub assemblies and my vibration issue was solved. Depending on the age and how many miles your car has, it may not be a bad idea to replace them.
Thanks for the replies. I think I will just try replacing those as I already have one sitting in my garage so it couldn't hurt. Im at about 102k miles and to the best of my knowledge they've never been replaced.
