This is ALOT different then the one I bought.. Mine had a wire for the ground and then a red wire that I just plugged right into my fuse box....
Hi All,
Bought a set of indiglo gauges, just need a shred of advise wiring it,
Have searched the forums and found some info but the wiring on mine seems to be different,
Im assuming the part with the hole should be grounded on a bolt or some such, i just have no idea what to do with the other bit.
As you can see there is a red and a black wire, im going to connect it to the dimmer rheostat wiring but the wires on that are green, black/yellow and black, which does the red go to and which the black?
Thanks guys
Ohh Yeaah almost forgot, i cant get the bloody needles off either
the gauges' red wire should be connected to the green/white wire in your fuse box area. that is your parking light wire.
