Thread: 4g63t / AWD 7g Build
Page 15 of 23 FirstFirst ... 5111213141516171819 ... LastLast
Showing results 281 to 300 of 445
  1. #281
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    I pulled the block and transmission out today along with disassembling the front cover on the engine. The oil pump looks really good. I'll take it to the machine shop and see what he says about it. The timing belt looked like it was brand new as well. I cut it getting the head out but I wasn't going to reuse it anyway. I'm contacting the previous owner of the Talon to see when the timing belt was done and to find out if he used new pulleys/tensioner. If those are fairly new I'll go ahead and reuse those.
    Unfortunately the driver's side motor mount is completely shot. The center rubber chunk pulled straight out of the housing. I'll have to check on an OEM replacement. I considered going with urethane mounts for about 10 seconds and decided I want this car to stay comfortable so the mounts are staying squishy. My Talon with urethane mounts vibrated like a motorcycle at stop lights. That was with balance shafts in the motor too. Speaking of which, I will be leaving the balance shafts in on this build.
  2. #282
    Experienced TGC Member
    12-27-2005
    Charleston SC
    1,520
    2.4 with no balance shafts and poly mounts= toothless. My gf's 63t with no balance shafts was ok. We didnt have poly mounts in it though. And go for OEM mounts for sure. Aftermarket rubbers suck ass. I blew rear roll mounts in 1 year.
  3. #283
    04-02-2009
    Denver Colorado
    1,447
    Quote Originally Posted by eclipsh View Post
    Thanks, I'll hit you up when I've got the funds. I'm already spending more than I should just building the engine.
    Quote Originally Posted by Shadow19 View Post
    How much can you get a hx35 for?
    I will have to see what I can get them for, hopefully I can get a decent price though and turn them around to you guys. We take them off the Dodge trucks all the time to upgrade to the Aurora 3000 Turbo we offer (basically same as the HX35s but more air flow).
    3G Eclipse Performance & Development - Denver, Colorado
    www.blackheartmotors.net
  4. #284
    09-06-2008
    533
    Got another fun surprise while I was cleaning up the garage a bit today. On a whim I grabbed the input shaft of the transmission to wiggle it back and forth. It should barely wiggle in and out, 0-0.0020 in. of play is specified by the factory. I think I could almost play Foosball with the input shaft the way it is now. So it looks like I'll be pulling the transmission apart again and checking all the bearings and their preloads. I'm hoping I can just order some new shims and call it good. Last time I looked the synchros appeared to be in great shape. While I'm in there I'll double check everything though including the seals. These unexpected expenses suck but putting parts back in knowing they aren't good and I'll need to pull them again later sucks even more. I've rebuilt one of these transmissions before so I know I can do it but I'm not looking forward to this one bit.
  5. #285
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    I would love to learn how to rebuild a trans... I could probibly do it but im nervous...
  6. #286
    09-06-2008
    533
    Saturday I opened up the transaxle that was in the car and went through testing the preload on all the bearings. I think someone really messed with this tranny. Two of the bolt holes don't line up properly and the gaps for the shim areas are HUGE. Mitsu doesn't make a shim large enough to fix the endplay. I think someone was mixing and matching housings on this transmission and didn't quite get it right.
    So I pulled my spare transaxle apart this morning. I got it as part of the trade for my 1g DSM. It turns out the spare was very recently rebuilt. The synchros look fantastic and by feel the preloads are way better than the other unit. Someone took the center differential apart and rebuilt it too. For some reason though they didn't replace the keys in the synchronizer sleeves. They are badly worn and will need to be replaced. The keys in the first tranny are in great shape so I may just cannibalize them. Oh, the seals on the spare were also replaced and are in great shape. With the good set of keys (and maybe sleeves) it should shift great. One odd thing was the spare was missing the steel ball which holds the rear output shaft in place. Without it the shaft just slides right out. The transfer case won't let it go anywhere but it can't be good having it loose in there. I'll pull the ball from the first tranny and put it in there. If all goes well I'll have one good transaxle back together soon.
  7. #287
    09-06-2008
    533
    I found out some more interesting info about my transaxle. I found some odd differences between the two and wanted to know what was up. Jack over at Jack's transmissions chimed in and offered me some help. Lots of pics of gear clusters in the link for all you pic-whores ;)
    http://www.dsmtuners.com/forums/driv...t-gearset.html
    It turns out I've got a hybrid 90, 93+ setup. That means stronger 3/4 gears but still double synchro second. I'll be pulling both gear sets apart and putting together one good one while keeping the other transaxle for spare parts.
    Still no word from the machine shop. My regular mechanic said if the oil pump is within specs and the scratches on the case are minor there is no reason not to reuse it. Good thing since I'll be putting some unexpected cash towards the tranny.
  8. #288
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    I dont know much about trannies, but i read that the strongest tranny is off 92
    Build Thread
  9. #289
    12-27-2005
    Charleston SC
    1,520
    Ive also read some shit about some of the awd transmissions being made by a company called getreg or some shit like that in germany. Supposedly those are bulletproof. However alot of the shit ive read on the internet has been dead wrong lately.........
  10. #290
    12-17-2004
    Louisville, KY
    4,327
    3kgt vr4 trannies were Getrag.
  11. #291
    09-06-2008
    533
    ^ Correct. If there were bulletproof gears for DSM's people would be all over them. If you start hitting the 400-500hp range on these gears start breaking. Fine by me though since I don't intend to go over 400 at any time since avoiding turbo lag is half the fun of putting my 2.4 build in the car.
    mko, I'm not sure if the '92 is particularly strong. Jack says the 3/4 gears out of the '90 are the HD set and he sells these as an upgrade for other years. I think once I have one of these together I'll be in great shape. I've already got roller bearings for the shift linkage, tightened up the sifter to eliminate slop and pulled the rear rubber bushings on the shifter base and replace them with large washers. With good synchros and quality gear oil this thing should shift great and hold up to all the abuse I'll be throwing at it.
  12. #292
    09-06-2008
    533
    I went over to my dad's house yesterday and pressed apart all four gear clusters. Now I need to pick and choose which gears I want to use. More pictures are up over on Tuners.
  13. #293
    09-06-2008
    533
    I spoke with Jon at TRE this morning. We went over my photos and options for the tranny. He spent half an hour on the phone with me which I thought was awesome given how busy he must be and how little I was planning on spending. He's a great guy and really knows his stuff. Explained how Mitsu made the gears, how strong they were and how much stronger shot peening gears makes them. He also told me some stuff I'd never run across like earlier spider gears in the front diff being stronger than the newer ones due to how they were made. Oh, and his prices were better than the competition :)
    At any rate, it looks like I'll be getting a new 1/2 synchro hub/slider set, new double syncrho set for 2nd gear, new 5/R hub/slider, a torington bearing for the center diff and everything shot peened for added strength. I'll also get fresh bearings and non-reusables. Unfortunately that means I'm dropping up to $700 or so on the tranny rebuild but better to do it now than later.
  14. #294
    09-06-2008
    533
    Hey guys and gals. I heard back from TRE on Tuesday. Crazy thing is that is the same day UPS said the package would be there. Same day service, how about that. At any rate. The gears looked great and I sent him my earlier model front differential in hopes it had the stronger spider gears. Turns out it did so that'll be nice. Everything was magnafluxed, shot peened and he's putting the clusters back together for me too. Turns out I sent him more gears than he thought I was going to so the price went to $845. That one hurt since I wasn't planning on buying ANYTHING for the transmission when I went into this. Still, I'll have a really nice "new" tranny going into the car that should shift great.
    I also finished up another little side project for the car. I've always disliked the raised lettering on the valve cover as it is a place for dirt and grime to collect and is a PITA to get cleaned out.
    I picked up 500* engine primer and paint and did two coats of each for the final product. Yeah, it seems silly to do aluminum color paint on an aluminum valve cover but it made it a lot easier to deal with and I'll be using the same paint on the block when it comes back plus maybe the tranny if I have enough left over.
    I also got in my new Gates 4G64 DOHC timing kit, hydraulic tensioner and head gasket from Rock Auto. They had the best prices I could find by far. I've already got my full gasket kit and new seals for the timing cover. I need to scrub down the rest of the engine components and I'll be porting the intake manifold for a 1g N/T throttle body I have lying around.
  15. #295
    09-06-2008
    533
    Got a package tonight.
    Everything was really well packaged. I think he threw in a new 1st gear synchro too. Hopefully I'll get it back together this weekend. I've got gear oil on order from RRE and should have everything else I need on hand minus some new hoses. I called to bug my machinist a couple days ago and I may be getting my engine back this next week.
  16. #296
    coming along nicely. too bad TRE doesnt work with automatics
  17. #297
    12-17-2004
    Louisville, KY
    4,327
    that diff looks wide open to me :D
    When are you going to come out this way and let me drive it?
  18. #298
    09-06-2008
    533
    Thanks qnz :)
    Indeed it is. I looked at their front dif insert but decided against it after talking to them about it. It will eventually wear down parts and cause issues I don't want to deal with. I've been eyeballing Evo 3 LSD's but the nearly $900 I had to spend on my tranny rebuild was a completely unexpected expense. It basically doubled what I thought my cash outlay for this project would be.
    You know those roads go both ways. Get your butt out here. There is less traffic and better roads to drive anyway ;)
  19. #299
    09-06-2008
    533
    I talked to my buddy Rick this morning. He was out at the machine shop yesterday and said they were finally starting on my engine. I'm hoping to have the car ready for a road trip to the L.A./Pasadena area we're planning for next month so hopefully things will come together.
    I've been ordering other parts for the car too. I picked up a set of Tein pillow ball shock mounts for all four corners on eBay, new for $170 shipped. I was going to build the Dennis Grant setup but this was half the cost. Rick will be cutting down the spacers for me and I got the spring hats for $20/pair also off eBay. This should get my shock assemblies all set for the way I want them.
    I also managed to tighten up the shifter a bit more by shimming it some more with sheet metal I have lying around. It had a little side-to-side wiggle in it where the vertical shaft bolts onto the rest of the assembly. That's gone now. I also managed to fix the air bag system I damaged when I was first building the car (damaged the clip on the computer) and I think I have the cruise control properly wired in now. I still don't know what's up with the A/C system and really want that working before I go to Cali. My wiring diagrams look like I got everything right but with swapping ECU's it is hard to tell.
    My mother-in-law (who rocks) is coming over to watch my 4 mo. old daughter today so I can go crawl around under the car. I think I've got a small leak coming from the yoke going into the t-case. I'll be pulling that apart and filling the freeze plug up with high-temp silicone so it can't give me any issues.
    I'm still waiting on parts for my tranny. I sent an email out to TRE this morning to find out where they are at. I didn't get all my non-reusables in the first package and I need the shims to set preloads on the gears. The case is all cleaned up though as are a whole mess of other parts I've been washing in the kitchen. Once this is done I really need to put a big sink out in the garage.
  20. #300
    09-06-2008
    533
    Lots going on now. I got the transaxle back together yesterday morning. Everything went together smoothly. While I was doing it the machine shop called to tell me everything was ready so I drove down and picked it all up yesterday afternoon. The head and block both look great. He also file fit the rings and installed the crank/pistons/rods for me. I also got a couple nice surprises. We were going with Topline bearings on his recommendation (1/3 the cost of Clevite and he's never had a problem with them in performance motors) but his distributor was out. The distributor mentioned having the Clevite ones in stock but my machinist said they were just too damn expensive. So the distributor says, "I'll cut you a deal, how's $96?" So now I'm rocking Clevite tri-metal bearings in my engine for $30 more than the Topline would have run. The other nice surprise was that he took a look at the oil pumps for me and said both were fine but one looked practically new so he cleaned it up to look brand new and reassembled the pump.
    Now that everything is home all I've managed to do is get the block on the stand and clean up the balance shafts to go back in. Right now I'm trying to decide if I want to copper spray the gaskets or just stick them in dry. I used copper spray when I put my 4Runner's 22RE back together and it sure made installation easy. Last night I went digging through the factory manual and printed out useful pages with torque specs and diagrams to make sure I get the right length bolts in the right holes and to generally avoid fucking things up. I'll be trying to take my time on this rather than working at my usual fast pace. I want this puppy to be perfect. I'll get some pictures going as everything comes together.
