you can either go with a separate buy of buying lowering springs (look at tein or eibach for lowest) and buy a replacement shock (kyb gr2's or kyb agx, the agx are adjustible on stiffness and camber i believe) or buy full out coilovers, with are an already pre assembled adjustable full suspension peice that is adjustable on height and stiffness and everything.
look at some build threads on here and look at what "drop" you like best
