Picked up the gasket kit, this is all i should need as in seals correct?
Thanks guys, i'll cut down the gap then.
00 Galant ES Turbo/5-Speed
13 GTR
13 GTR
I would say gapped at .028 dude
I sure don't, do you?
Yeah Ron thats the gasket. Piece of advice, it might be a PITA removing the old gasket, if it is, just take your time and get it ALL OUT. Get some gray RTV silicone and put a few little dabs of it in the gasket groove on the valve cover, it will help hold the gasket in place when you flip the valve cover over to install.
4G64/63T
AEM EMS
Thanks for the tip stewi, 1st time removing the valve cover. figured this is something easy i could tackle instead take it to the shop. Thanks for the help guys!
13 GTR
yeah the last SOHC valve cover I removed from an 8g was GoldGalant-REBORN's car. It took me about 45 minutes to get all the old pieces of valve cover gasket out of the valve cover because it was stuck, I ened up using a small flathead screw driver and a torch to heat it up.
4G64/63T
AEM EMS
After 30 mins I got the valve cover off! You were right about it being stuck on, luckly walmart was 24hrs and I got a rubber mallet. Few questions:
1. Is it better just to install the spark plugs while the valve cover is off already? Should I use any grease on the threads?
2. Tube seals, do I just put dabs of rtv so they stay in place? My current seals, two are on nice and tight, while the other two were just loose which explains the oil on this plugs.
13 GTR
4G64/63T
AEM EMS
Do I let the rtv fully dry before putting the cover back on?
13 GTR
No just apply the rtv, push the gasket into place and the tube seals into place, wait like 10 minutes and install it.
4G64/63T
AEM EMS
So just updating the thread, after i replaced the plugs/gaskets the car started to act normal. The bogging went away, until today. 1/2 throttle 55mp, the wide band went very lean and car bogged, which then i let off the peddle and re-applied and went away. couple miles later, the car went rich and bogged. I have no idea what's going on, ill see on my ride home tonight what happens. Ill re-pull the plugs, but any other idea's whats going on
Video of the initial start up after new plugs:
13 GTR
Sure you didnt blow off an intercooler pipe? If not, and no vacuum leaks, you need to check for spark on each plug wire.
I checked all the connections & clamps on all pipes. Stewi, i had the same tune for over 2 years, maybe it might be time to get it re-tuned?
On the ride home, car sputtered veryy badly to a point where i had to go 20mph all the way home, another cell P0303, pulled all the plugs no oil nor anything wrong. Im going to check for spark like seth advised. Here are few vidz, maybe you can get a better understanding. It sucks, the shop I used to use moved to cali, nothing close by besides nj/nyc. 1st time in the 10years of owning this car, it really caused me an issue, im hoping its something minor which i can tackle. I also like to say thanks to you guys, since im lost and your my gateway to get this car back on the road.
The ride home:
13 GTR
ron you have the E-Manage blue right?
maybe it's shit the bed. i remember people back in the day had issues with them loosing their tune. just a thought
Ron does your wideband have a hookup to connect to a PC? If it does, program it so the gauge displays AFR changes every 1.5 -2.0 seconds. It will prevent the gauge from being so crazy going up and down while your driving, it will still show the correct value, it just wont be flickering all the time.
It could be the tune, the emanage could be bad, it could be a cracked intake manifold causing a massive vac leak. I would try doing a boost leak test first before I got into re-tuning and stuff. Maybe try swapping out the ignition coils if someone is local to you that you could try theirs to see if thats the issue. To me, the way it sounds in the video it sounds ignition related. Igniton probs could be the emanage, coils, wires, TPS sensor, a loose wire on the cam or crank sensor, etc.
4G64/63T
AEM EMS
How are your EGTs? One time this past winter, I had a similar problem to yours. I couldnt go faster than 30 mph, AFRs were 16+, EGTs were 1400+. I parked the car and the next day it was "better" but but far from good. My problem I think was the weather was getting colder. I tuned around it and now that its summer, my tune is still OK.
Maybe its time to go Evo 8 ECU. I have a spare on sitting on my desk right now you can have for free. (just kidding Jesus!!) It belongs to galantfan88. lol
I did not checked the intake manifold for cracks, good call. ill go through the list you posted and see if anything helps. Qnz, egts were all normal. It has been very hot in DE compared to last two years, maybe a re-tune is needed after i check the other possibilities you guys posted. I need to look into the evo ecu, see if its something i can tackle or not
13 GTR
Brian, you wanna take a ride out to Delaware this weekend? Its 2 hrs from NYC. Not too bad.
that be a life saver! gas+tolls+food on me!
13 GTR
