Thread: Galant no spark
Showing results 1 to 19 of 19
    Galant no spark
    Hi I've just bought a 1994 galant es.
    I was told that the car has a distributor problem.
    I've put a distributor that I have of a 1996 galant s on it.
    The engine turns over, but has no spark.
    I've checked the engine fuses but everything seems to be fine.
    What else should I checked for?
    One more question I have, does the 1994 use cranksensor?
    Cause I don't see no wires go to the timming case.
    Need some help asap.
    Thanks
    TGC Regular
    11-14-2007
    Boothwyn,PA
    719
    I think the 96 distibuter is different then the 94-95 if I am not mistaken...
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    94-95 dizzies have cam and crank sensors in them and 96-98 dizzy only has cam sensor. Thats why the 94-95 dizzy is much bigger.
    Try to find a 94-95 distributor
    Build Thread
    12-17-2004
    Louisville, KY
    4,327
    bingo
    Well I'll have to look around for a 94 distributor, hard to find parts here, which other car uses them? only the galants?
    only the galant's use galant's distributor, cant adapt another,
    __________________
    Try ebay or somewhere online.
    i had one but sold it with the motor
    i HATE 96 G's Distributors :@
    2 distributor in less than 5 months. and im looking other one,!
    Fking PO340 failure =/
    __________________
    I've open up the 1994 distributor, and found out that the module is broken.
    Can't find one anywhere arggg
    09-20-2007
    Sea Isle city, NJ
    4,098
    these are 70 bucks on ebay
    Build Thread
    Well got a 1994 distributor today.
    Strange thing is that the distributor was on a 1997 galant and the engine uses a cranksensor
    The engine starts and run with the 1994 distributor.
    I just change the distributor, and put my 1996 one on it, and the engine runs as well.
    The strange thing that I saw is that the intake manifold doesn't use the sensor on top of it
    I want to understand this correctly. You said in first post 94 distributor was bad and 96 distributor wouldn't fire, then you tried a 97 distributor and it worked. So all the distributors now function in your 94? I wonder if your market is different as far as model year changes? Are all the caps the same size do they interchange? US market units are considerably larger for 94-95.
    Ok let mi explain.
    The distributor that was in the 1997 galant, was a 1994 galant distributor.
    It has the number T6XXXXX.
    I don't know why the 1994 distributor worked in the 1997 car.
    I got the 1994 distributor out and put the 1996 disti in the 1997 galant and it worked also.
    When I was putting the 1994 disti on my 1994 galant I saw that the cranksensor wire was cut.
    But strange thing, the car starts and runs fine.
  15. #15
    Now I understand. Where is crank sensor wire cut at distributor or elsewhere?
  16. #16
    It's cut near by the end of the intake monifold,so half way to the crank
  17. #17
    The 94-95 cars use a simulated crank signal off the distributor (signal from the cam not from crank itself). If you truly have a wire penetrating your timing belt cover then someone has replaced the motor with one a little newer like 96-98. Don't worry about it as computer only needs 1 crank signal and the distributor is supplying it.
  18. #18
    1989 galant 2.0 ,no spark from distributor.how to trouble shoot
  19. #19
    07-02-2011
    South Florida, by the beach
    1,076
    have you tried a different distributor?
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
