you drive?
Brembos installed. I like.
Yeah right after the picture, I threw the wheels on and made sure everything was functioning properly. They feel good so far. Without ABS they are noticeably less prone to "locking-up" and actually stop the car. Needless to say, I'm pleased.
It takes a bit more pedal to feel them. I was anticipating that after reading about it, and sure enough, it's true. But it's not bad.
oh hell yeah that happened to me too, thats why i whent w/ the brembos
________
Body Science
probably. SS lines are one of the next items on my list. I'm also using the stock rear calipers for the time being.
Hey.....I found something you might want...
http://madison.craigslist.org/pts/1927466881.html
still waiting on the 2.0 Tatrix connector?
Out of curiosity why did you went with the 2.0 tactrix when you can get the 1.3U its cheaper and faster at datalogging? Or you just found a good deal on the 2.0 on evom?
4g64T 5spd
2.0 cable can flash the 2000 ECU
I got all of the connectors needed finally except ecuflash has no clue what my roms are. I've pulled my 99 fed spec ecu and my brother's 01 cali spec, but ecuflash has no info on them. I'm stuck.
I am so bad with tuning. But I'm assuming you checked out that 2000 to 2001 ECU swap thread? or the flash thread on club3g
1994 GS FYI
DSM/CSM Manuals
looks like my G is done until spring. Blew up the tranny. Sounded pretty bad like a bucket of coins spilled all over and it's steady pissing gear oil. Well, time to start thinking about next summer.
