well best bet craiglist
hey forum,
during the last 2 gas tanks, i've been filling my passenger front tire up with air. I went to discount tires today and i thought it was just a slow leak and come to find out, there's a crack in my rim! they put some sealent on the crack but hopefully it will hold up until i can replace ALL my rims. My question is can I buy a GTZ wheel & tire just for my front passenger tire? I have 18' rims and I wonder if I can get the GTZ wheel will my balance be completely off with the 1 different tire size?
The 0ne & 0nly King D
8th and 9th gen galants
They should have told you they can't fix it. A cracked rim is structurally no good. Replace it asap.
yea dont wanna ride on 3. maybe two but even that isnt a good look craigslist like posted above is the best option in a hurry.
2002 5spd swapped
under construction.....
I've had 2 rims welded before and they both cracked again later. I actually found a guy selling 2 of the same rims on Craigslist. I was lucky as fuck to find them, just check it everyday. It was buy the 2 rims from dude (because they are discontinued) or scrap them or buy the moda r6's for $400. You might find a set on Craigslist that you like better or find the same rim/rims for sale. Goodluck with your search, I've spent the past few months searching.
As long as the outside diameter is very close you will be fine with the GTZ wheel until you buy a new set. 205-50-16 and 225-45-18 will have close to the same outside diameter.
the rim is crack in the inside but it's a very small crack. maybe abt an inch. I'm definitely looking around but most likely, i'll just buy some stock tires... thanks for the input guys :)
Sorry i meant to say 205/55/16 and 225/40/18 have about the same diameter. Thanks for the catch.
ok i went on ebay and saw a 18' rim for the 09-10 galant. will it fit my 02? there's the link below
http://cgi.ebay.com/ebaymotors/ws/eB...m=280487994122
Rim Information
Rim Brand: Factory, OEM Number of Bolts: 5 Rim Material: Alloy
Rim Width: 8 Bolt Pattern: 5x114.3 Rim Structure: One Piece
The link doesn't work for me but, yes 9g wheels fit on 8g's
4g64T 5spd
+1, hondakillergtz has them on his 8g.
