Originally Posted by
03chi-town0z
changing tires will help your outer clearance, but if you're hitting on the inner wheel edge, you'll need spacers or coil-overs. with the spacers pushing the wheel outward tho, it'll probably mean you'll need different tires too, but i wouldnt spend the money before you know for sure once the wheel is fitted up properly. i know greddy has some work done to fit his 255's but he's also lowered. if youre at stock ride height, you might be ok with the tires you have on if you make sure you drive like a grandma over bumps and potholes. you got a pm...
