they come with the spanner wrenches to adjust the height on them, the dampering is a twist knob. but to install them you need like a 14mm to 24mm just for the different sizes, bu there arent that many bolts
Seems easy enough, im assuming they work with the stock strut, and im looking at a skunk2 kit for 150 on ebay is that any good?
http://cgi.ebay.com/ebaymotors/Skunk...Q5fAccessories
no no no no do not get those, they are complete garbage do not get those. those arent true coilovers they are coil sleeves. if you want a budget go for either d2 coilovers or meagan coil overs they usually run under $950 shipped, the k_sports and tein basics run about $1200 the tein ss'p run about 2000. a coil over is a single unit all one part, there is no buying struts and springs, its all one peice.
ah okay, i have really shopped them around i always say the ksports in 1200 range, but i havent really priced shopped as i am looking at a different set of coilovers
1500 limt for lowering or your entire suspension?? cause with lowering polyurathane bushings are recomened, new sway bar endlinks, and sway bar bushings. you could even get e bigger sway bar for the ultimate performance setup
then i agree with cody go for the k-sports. you may even have enough left over to get the polyurethane bushing kit for the car.
I myself am going for the d2.
or elcheapo parts for other platforms hahah
You can get D2's for like $830 shipped: http://www.weaksauceparts.com/store/cart.php
4g64T 5spd
or you can get D2 from kalvinsaid for $700, Hes been trying to sell them since august... https://www.thegalantcenter.org/showthread.php?t=42677
shhh dont tell him that, when i get the money i was going to buy them from him ahahaha
im just messing around haha, though i would like to get them if i had the money![]()
