moar low + moar camber + 215's = they'll fit
so, I order a new set of 18" XXR wheels,I did not check the width, or the offset, now I am stuck with a new but useless set of wheels, when I went to get them installed, I ask to try them first, before get the tires installed, and the result is that the face of the wheel is almost 1" outside the rear panel. I almost cry, but now I know better: a 18"x8.5" w.30mm offset will NOT FIT.
De que estamos hablando?
I'm running 225/40r18 on 8" rims and 30 offset had to roll the rear but they fit...
I would love to see them fit, but they are 8.5" wide, they sit almost 1" outside the rear edge; I roll the edges in advance, thinking they may rub, but I think they are too outside.
im running 18x8 +25 and I only need to roll my rear fenders...they should fit.
I would like to see if someone have 18x8.5 w. +30 offset and how; that may give me some sort of hope; for now, I am looking for a set of Lancer GTS wheels.
Well try to sell them and next time do some research,especially something so expensive
Dude I run 17x9 +27 with 255 width tires they will fit
those wheels can easily fit dude! Dont sweat it! get a fender roller
They should fit I also am runining 18x8.5 with 225/45/18 and I'm good
