Looks sick man!!
Does your Home Depot lip look ghey and want a different front lip for the same price? Then read on my friend, read on.....
How to: Install OEM 94-95 Accord Lip (CD5) on an 8Ga & 8Gb bumper
The CD5 lip came in two sizes (well 3 if you include the 96-97 models): medium & large. I tried both of them and fits just fine (that's what she said).
Medium lip:
Large lip:
To determine the height, use a small measuring tool. Medium is 2 1/2 inches high and the large is about 4 inches high.
Here's what you need:
- Front bumper from a USDM 8G (1999-2001), 8GB coming soon
- some sort of cutting tool (Dremel, power cutter, heavy duty scissors)- double sided tape
- about 16 10mm 2 inch bolts /w washers
- 10 mm ratchet
EDIT: this lip can be applied to 8Gb bumper as well (2002-2003)
I know this is off subject but how hard was it to put that front air insert on the bumper? It looks awesome. I have mine and i wanna install it next week :)
I got mine off a 92 i am going to try to put it on, it looks very similar.
What about the rear lip??
he was so pose to show a rear lip with jdm bumper i think.
hey lip master, where's the pics of the rear
5spd swap
full custom body conversion
18x9 Works VS
Big 16g evo3T next project
My camera's broke that's why I haven't done much but the fitment is pretty good....
You may need 2 sets of those lip to get the usdm bumper to fit. One for the curves and the other is for extending the sides. As for the jdm specs it takes only 1 set to fit. I know without pics this means little to you guys but I'll buy another camera soon.
Sorry for the delay but here are the pics....
These are from...you guessed it, from a CD5 Accord :D
Sorry for the not-so descripted pic but if I didn't have a rear valence & lip this would of looked a lot better. As you can see, it needs to be slightly extended (for jdm specs), usdm a little longer. I tested this lip on a 7G bumper and found out it needs to be trimmed down slightly but overall looked good. Now if I could only get the guy to stop by and test fit it that would be golden. **cough**Warren**cough**
Front View
There's another piece not included in these pics, a middle piece that completes the whole lip. The other part is the tail pipe section needs to be trimmed to fit the exhaust. That's so far what's going on right now. I really need to have a local 7G and a usdm 8G test car to get finish this project. Without that, it's just speculation. It costs me $8 for the whole thing this is not the kind of project to be overlooked. Thanks for reading :)
what about warren isn't he local
5spd swap
18x9 Works VS
