Made some answers, head swap isn't that bad. yes the list is drawn out and frighten but it's really not. Beside, why not try to swap the whole G4JS in your 8G?But ok theres a bunch of G4JS heads sitting at the jy. But some things are keeping me from pulling it.
1. question: why do i need a adjustable cam gear for one of the cams? as i heard it would be to fit the belt. but isnt the 4G64 DOHC belt identical to the G4JS?
To set the timing, if you prefer for obvious reasons: Milled head, decked block, etc. At least one adjustable cam gear WITH an Evo cam gear. The 4G64 DOHC belt will make the swap a breeze. The G4JS cam gears will not work with the 4G63/4 belt and vice versa, or stick with the G4JS cam gears and belt.
2. question: Can i use a G4JS belt? i really need some ones expertnesses.
See answer to question number 1
3. The only thing i would need from the evo is(cant remember the name) but are ecu cant read the G4JS one for timing. Where can i get this part?
Are you talking about cam sensor? Swap the 4G64 cam sensor, housing, and wheel to the G4JS head. The Evo and 4G64 has the same cam output signal.
Im pretty close too just running down there and pulling a head. All the sonatas in there are under 140k and the one i got my pistons was 86k.
1994 GS FYI
DSM/CSM Manuals
1994 GS FYI
DSM/CSM Manuals
If you find a G4JS head untouch, you are good to go but remember the valve springs are weaker than the Evo valve springs so upgrade them to some used Evo ones. BTW, G4JS pistons with 4G64 head=11.5:1CR
1994 GS FYI
DSM/CSM Manuals
Good to know ill deff end up pulling the head ill just have to wait longer to put it on. 11.5:1 is to high for my likings.
that is a perfect ratio. What is too high about it? If you want to see some good number low compression is not the way to go
Just to clarify...The G4JS pistons wont go in an clear the valves without having the +1 mm valves? Am i wrong?
A mild combo like HKS 272/264 & BC272 will most likely clear, something like Kelford 272 or Tomei Procam will need the pistons to be clayed to check for clearance.where did you here that from? they drop in and clear the valves. But according to mystic they might not clear with a aggressive cam. That Info is here in this thread
1994 GS FYI
DSM/CSM Manuals
ok ok, my bad i was actually thinkn +1 was actually a shorter valve to clear the height of the G4JS.
eclipse ecu is your best bang for the buck if your 5 speed, dual ecu's if your not
the eclipse does have a knock sensor so and evo ecu is not necessary for that reason, im using a 02 eclipse 5speed ecu and flashed an evo rom into it no problems there you just need to adjust the tables
you need the evo reluctor to go on the end of the exhaust cam, get it from mitsu and dont forget the bolt also its like $20 if i remember correctly
i highly suggest you get the evo intake manifold, the stock g4js intake manifold works fine but is too tall if you decide to use a straight across strut bar it wont allow for clearence, the long runners are nice for a little torque boost tho.
if you have other questions post them on here and i'll try to answer them as best i can but its been awhile since ive been heavy into this stuff.
i have pictures of a lot of stuff so if you need something let me know and ill see if i have them to post.
goodluck with your build
naw i shipped out before i got to swap in the evo i/m, new clutch and flywheel, and do the tuning. i just got the car smogged (another benefit to evo rom, there is a patch to pass emissions testing no matter what). its running way rich and i havent driven it for a little over a year so im getting back into it and first getting in corner balanced sway bar and rear camber kit and aligned then manifold and clutch/flywheel then im going to jump into tuning it
i work too much now and im in an apartment so i dont have a garage to work anymore i gotta take it to the autoshop on base
