replace the driers side switch for that door if poss. sum times if that one fails it will bypass the switch in the line drivers is first thats why you have a lock on that door only it controls all doors
So about 3 1/2 years ago my passenger window went out. at first it just quite and for about 6 months it would work sometimes and sometimes it wouldnt, it finaly just quite working at all. well I finaly got tired of it today. so I went to the junk yard and picked up a new motor for $45 alittle high but it was the only one within driving distance. But it didnt fix it. I tested the new one and it works. when I try to roll the window up there is a clicking noise that comes from the passenger side switch. but the passenger side switch works on the back door so its not the switch. it also makes the noise when I put the back switch on the front. Has anyone else ever had this happen or know what is happening? does anyone know how to fix it or any trouble shooting options?
Thanks
I found this thread via search. I'm having the same problems.
I will try the infos you have posted and try to see a mechanic.
Thanks.
I wanna be a Billionaire... so freakin' bad...
yea if you have ever notice when driving in the rain with the windows cracked all the water comes in and drips on the window switch. I had this same problem before.
1996 galant s
i just replaced my master window switch cuz it stopped rolling down the passenger side windows but it would roll them up lol
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
swap to manual windows. problem solved
