Most likely some bushings probably melted. examine your sway bar links and bushings and your control arm.
99 galant LS 6G72, front springs were melted and front end was sittin on the ground when i bought the car for $1400. Since then Ive changed to Tein springs, KYB struts, R.side new hb assmbly,cv joint, knuckle, hanger bearing bracket,driveshaft, and the car still seems to ride kinda.......Loosley, I'd like to stiffen up the suspension. Any ideas, also really annoying belt squeak when steerinmg wheel turned all the way in 1 direction, and also inferior handling compared to my I4. Any help would be greatly appreciated.
Thank you,
Joe
No problemo
