Thread: which is the best??
Showing results 1 to 17 of 17
    which is the best??
    i need help for engine oil,,so which one is the best for our galant,,amsoil??mobil1 or castrol?? should ill get 5w-20 or 10w-20??10w-30,,5w-30??
    thank you so much
    8th and 9th gen galants
    nevermind i just use search button abd i found a thread about oil,,so amsoil ftw!!
    06-16-2010
    Fort Mill, SC
    2,282
    Check out the thread that debunks all of the oil myths. I'd search it for you, but my iPod won't let me.
    Sent from my iPod touch using Tapatalk 'cause I'm awesome
    -Andrew
    i think i found it,,thank you a anyway
    TGC Regular Da_Prodigy's Avatar
    01-29-2010
    Elgin,IL (Chicago Suburbs)
    593
    I use castrol gtx, I found to be pretty good.
    so how many quarts should i put then??
    and i think chaotic customs sell some amsoil,,i heard castrol gtx i good too
    I'm loving Pennzoil 5w-30... My oil light used to come on when changed my oil pre-pennz... then i switched and let it run for 20 mins... it did what it said it would... Kill the sludge... I will never use anything else... Especially when i get it for $10 flat
    "Triangle Circle Triangle Square"
    Icon2
    Quote Originally Posted by madkilla View Post
    Your only suppose to put 3.5-4.5 quarts, anything else would be flooding the engine...
    05-14-2010
    Coachella, CA
    5,954
    Quote Originally Posted by BronxBlur23 View Post
    3.5???
    v6 takes 5
    i buy my amsoil directly off the website.
    if you plan changing your oil more than once, get the preferredcustomer memebership. mine paid for itself after buying 10 qts of oil.
    shipping is usually overnight for me, even with the cheapest shipping.
    Quote Originally Posted by dknight3 View Post
    v6 takes 5
    i only have i4
    01-29-2010
    593
    So put about 4quarts in it
    Then.
  15. #15
    TGC Regular P'NOYcaL's Avatar
    10-23-2009
    Bergenfield, NJ
    504
    I use castrol syntec, few of my friends actually thought my engine isn't even running whenever I'm on park. No tic or anything ever since I switch from mobil1 synthetic.
    ________________________________________
    -RON
  16. #16
    1996 galant s
  17. #17
    07-20-2003
    Orlando, FL
    3,169
    Where you do base that statement from?
    Penzoil consistenly performs well especiallly for its price range and better than more expensive oil in the market.
    Even Amsoil oil comparison tests show that Penzoil synthetic oil does very well.
