you gotta get it, It gives you peace of mind when flooring it .LOL.
Nope, just the V6 TB
-Andrew
You cut your springs?
:facepalm:
hows the ride with the suspension that stiff?
its not to bad but when u get those waves in the road it suck.i think i might turn the back down some i was told if to stiff it will crack my rim but to some it up there great!!
i am at +12 front and back, I think i need to go a little stiffer.
yea i had mine soft at first and it was bouncing but i think i might be to low
2007 Ralliart V6
WORKS Springs w/Bump Stops
Stock Struts
Stock Strut/Sway Bars
19" Axis Matrix Wheels +35 Offset
Goodyear Eagle RSA 245/40/19
Absolutely love the ride quality. Has an aggressive look, no floating suspension anymore. Doesnt bounce all over the place, but definitely feels more planted with its lower center of gravity. Rides like a Cadillac on the highway.
Would highly reccomend the springs to all 9g's looking for a drop.
Additionally, I was running 235/35/19 rubber, same brand/model tire. The ride was much firmer, and could feel nearly everything on the road. In all honesty, I hated the feel. So when those went bad I upped the sidewall, and went a little wider. All I have to say is, I will never run a 35 sidewall on this car again. It was like night and day going from 35 - 40. So if looking for a more comfortable ride while being dropped, I would highly reccomend the 40 sidewall. The tire model themselves are okay, the sidewall height is the important factor. My $0.02
D2's loving 'em
- If you've got nothing nice to say, what the hell is wrong with you!?!
Putting my suspension together right now.
Tein SS-P Coilovers (set +8 all the way around) Haven't quite adjusted right height yet
Prothane Total Bushing Kit - Black
Stock front sway bar/ Addco Rear Sway Bar
3g Strut Bar
Rear adjustable toe arms from Cali
19" TSW Montage
Falken FK452 235/35/19
Can't wait to get it all situated.
(PS I run a 2001 GTZ)
})({ Heather })({
- "If you never take risks, you'll have a wasted soul."
Been a biut but
BC suspension coilovers, set at 22 in front and 12 in rear, and its just perfect and i will go stiffer when i track or autocross.
Moog front enlinks
Oredering this week complete poly bushing kit, new control arms, rear megan control arms and calis adjustable toe arms
Ralliart/Mitsu Front Strut bar
Avenger Springs/Struts[Front]
Energy Supension Rear Bushings
3G/8G Rear Upper Tubular Control Arms
Custom made Lateral Arms Stiffers
Coming Soon...3G/8G Rear 18mm sway bar, endlinks, and lower arms with bushings; Sebring Coupe 95-00 Rear Struts/Springs.
1994 GS FYI
DSM/CSM Manuals
hey guys. random question, apologies for putting it here. it didnt really need its own thread.
could anyone be so kind to post a few pictures of each of the following 8G parts:
front shocks
front hubs
front lower control arms and assosiated brackets etc.
front swaybar mount points
secondly:
are these the LCA's you guys use in your 8G's?
http://www.ebay.com.au/itm/Eclipse-G...item56360daf52
@9GRalliart---Your car is giving me major wood! Sexy!
Hello guys, this would be my first post since i joined the forums a few months ago :D
I have a 2003 galant es 4cyl I was asking around how to lower your car (since i dont know much) and somebody mentioned the tein s.tech springs. I went on the website & did some research. The springs for v6 lower car 2.2 (front) /1.5 (back) in. & the 4cyl. springs lower it 1.7/1.3 in. my question is.. can i install the v6 springs on my 4cyl to get that extra .5 in. lower OR do i HAVE to install the 4cyl springs on my galant???? my car is completely stock (except rims ;) ) && i hate the huge gap on the front tires!!! please i need some advice from you guys!!
The springs that belong to your car will do just fine at getting rid of the front wheel gap. Dont go V6 if you don't have it. Make sure you get GR2/excedy shocks from KYB along with your new springs.
yeah somebody recommended the tein s.tech with kyb gr2. thank you sir.
