Thread: Azgalant's evo head build and 5-speed
Page 4 of 7 FirstFirst 1234567 LastLast
Showing results 61 to 80 of 131
  1. #61
    Yeah dyno before and after. See how much hp you gain from mods. Dyno with DOHC first them turbo
    Quote Originally Posted by Rach3T8G View Post
    I'm with Isaurio dyno before & after....
    Yea I am going to tune it next week this guy I know said he would be able to do it next week but just like a street tune and then dyno it see how it goes then after TURBO :)
  2. #62
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    Can't wait for the results...
    Sent from my BB Curve 3G using Tapatalk.
    - Chris -
    DRL Delete
    | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
  3. #63
    11-29-2009
    Chadds Ford, PA
    2,768
    Wow i jealous lol, i am going to the the same thing Dyno before M/T, after M/T, and After Turbo.
  4. #64
    Lol yup we'll see how it turns out and i'll try to update as soon as possible.
    Here's other pics on what I bought
    I have other tubing and that's it for now.
  5. #65
    looks good man thumbs up
    2002 5spd swapped
    under construction.....
  6. #66
    Experienced TGC Member Galantfan88's Avatar
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    I would say the only thing that confuses me is that you have the knock sensor coming through the fire wall and than into the connector that connected to the ECU but its not connected to the engine wiring harness itself. Is this correct? Im just trying to figure out where you got that extra green wire or where did you pull that out from. All of mine are connected...so what I am trying to figure out; should I just tap that red knock sensor wire into Pin 78 green wire even though its connected to the engine wiring harness?
    Evo 8 ECU / 5 Speed Swap / Fully Built Forged Motor
    Turbonetics Turbo T31 Stage 3 / RPW Stage 3 Camshaft
  7. #67
    Quote Originally Posted by Galantfan88 View Post
    Lol what I did was just kinda guessing because I couldn't find anything about how to connect the knock sensor.............I might be doing it the wrong way so if somebody knows a better way to do it let me know.
    What I did was cut the green wire that goes from the stock wiring harness to the ecu.......I just checked that the wire I was cutting was from slot 78 coming from the ecu. From there the green wire that was coming from the ecu I just connected the wire from the knock sensor. The other green wire that is loose is coming from the wiring harness that the car has but I believe that I checked it that slot and it was empty. So now I ran through the code thing and the knock sensor code if off. So either I did I did it right or something else is happening lol.
    I do have other codes on but they relate to the egr, fuel and i think the turbo solenoid.
  8. #68
    Wow great build man!! Props to you.. Nice choice on all the performance parts your going with and great work all around!
    I installed my knock sensor with my evo ecu acouple weeks ago. I put the knock sensor in the location of the pic that Stewi posted earlier and grounded it to one of the spots on the block(Made sure this was clean). Then traveled the red wire through the firewall into the correct pin on the ecu.
  9. #69
    Quote Originally Posted by Gtorque View Post
    So it sounds like I did the same thing just the red wire was too short for me thats why I extended it with a black wire.............that's why in the picture it looks like I ran the black wire through the firewall but it was just the red........i'll post some pictures on where exactly it is in the firewall.
  10. #70
    12-02-2008
    1,263
    Quote Originally Posted by azgalant View Post
    Yeah that would be awesome if you did get some pix man...it would help alot man. Good work
  11. #71
    Alright well here's a few pictures on where I drilled the hole at........I know I took awhile to get back at you but here it is
    This is where the hole ended up at
    This is from the other side
    Hope this helps
  12. #72
    Also another update my oil lines came in today and I just ordered the 1000cc injectors the brand is injectors dynamics hope those are good :)
  13. #73
    ^ Same injectors im running.. If i get my g up and going before you ill let you know how they are. Later on im gonna do a double pump system with bigger injectors.
  14. #74
    12-02-2008
    1,263
    Yeah deff thanx for the pix man
  15. #75
    Cool cool well they should arrive this week with my new Walbro 255LPH Fuel Pump that I just ordered so hopefully by the end of next month i'll have everything ready for the turbo to be put on but if you beat me let me know lol
    No problem
  16. #76
  17. #77
    Look what just arrived..............think I am done getting parts for the turbo just need to install everything hopefully by the end of the month.
  18. #78
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    cut the rpm wire that goes to the ecu problem solved, the evo8 ecu tach is an output signal, on the galant ecu its an input (pretty sure) so you have 2 outputs on 1 wire how I figured it
    evo8 ecu tach Output >>-----------------<<galant speedometer tach output
    let me know if this works for you,
    <a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&amp;current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
  19. #79
    Quote Originally Posted by duh2150 View Post
    Thanks but still confused lol was looking at the wiring diagram and couldn't figure which one to cut any help?
  20. #80
    TGC Regular
    07-16-2006
    Cocoa, Florida
    791
    Pin 58 from the ecu (Tach Signal (Output)) and I'm pretty sure the 8g reads the tach signal as an input to switch gears for the auto transmission
    heres the link http://www.roadraceengineering.com/e...-ecuwiring.htm
