Thread: Galant306m's turbo build
Page 49 of 65 FirstFirst ... 3945464748495051525359 ... LastLast
Showing results 961 to 980 of 1287
  1. #961
    cluster should get to u by saturday
    5spd swap
    full custom body conversion
    18x9 Works VS
    Big 16g evo3T next project
  2. #962
    Awsome dude thanks for shipping it super fast! Just stressin out over this tune coming up hoping I did everything right and nothing goes wrong
    Sent from my SPH-D700 using Tapatalk
    1996 galant s
  3. #963
    1996 galant s
  4. #964
    12-17-2004
    Louisville, KY
    4,327
    yeah I couldn't be less of the 7 miles of fuel hose running to where you mounted your regulator. Just curious is there is a reason you mounted it all the way over there?
    Thats a great regulator though. Don't forget to use thread sealant/tape on the threads of the pressure source nipple, as well as the adjustment set screw on top of the regulator. No one likes boost leaks.
  5. #965
    I looked to see where other people put them and that baicaly the easiest place. Its not perminate right now I have the option to move it that's is really just mocked up in those pics. Thread tape on all the npt fittings got a different gauge I'm ging to mount on the cowel haha.
    1996 galant s
  6. #966
    And kinda thinking about it the whole fuel system is preasurized so adding aother foot is not going to changeit much the fpr is still going to do the same thing there as it would with 6"s of line. It came as a kit for th dsm so I just followed what other people have done
    1996 galant s
  7. #967
    12-17-2004
    Louisville, KY
    4,327
    I think the easiest solution would be to relocate your alarm siren and mount your regulator in its place.
    Keep it up.
  8. #968
    Looks nice can't wait until you dyno it.
  9. #969
    Keep it up.
    Yea that is a viable option, i got everything hooked up and tested no leaks atm going to pick up a fuel pressure gauge tomorrow from the local performance shop with a pre made line so ill see what i can do with it. Going to put a gauge on the cowel for sure so i know what it is doing at all times and make sure that even at like a quarter tank, that im to low on fuel and that I will never have a lean spike or anything bad.
    Quote Originally Posted by azgalant View Post
    Thanks man can't wait till my dyno day! seriously not going to be able to sleep the night before!
    1996 galant s
  10. #970
    im going to have to come take a look at this one day... really
    2002 5spd swapped
    under construction.....
  11. #971
    Was working on it toda got it idling at 14.5 afr now fpr adjusted to get her idling right seems like my intake mani is leaking for to adress that tomorrow.
    Yea send me a pm dude I'm around the waukesha area
    1996 galant s
  12. #972
    08-13-2008
    Waterbury, CT
    3,331
    Get the Magnus heat barrier if it's the gasket
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  13. #973
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    Build Thread
  14. #974
    1996 galant s
  15. #975
    09-20-2007
    Sea Isle city, NJ
    4,098
    gotta play with that dsm link. what injectors are you running?
    Build Thread
  16. #976
    750's
    1996 galant s
  17. #977
    Can't find my dsm link cable atm :( and I have fuel pulled becase it was running so rich
    1996 galant s
  18. #978
    02-17-2011
    i live in sunny florida
    1,240
    danm son keep it up i just read all 49 pgs u bought stuff and then u bought better stuff makes me wonder y, lol did u even get to use those springs before u put the coilovers on??? lol
    keep it up bro u will get it running right
  19. #979
    yea i used the tokico's for a couple months they where ok, i just want to have full coilovers really! thanks man been a LONG process! Going to get better this winter though.
    1996 galant s
  20. #980
    09-20-2007
    Sea Isle city, NJ
    4,098
    did you scale down the injectors or is it still set for 450cc? What about the dead times?
    Build Thread
