i know this is for an eclipse but it shows u part of it. its a big help
http://www.eclipseforums.org/showthread.ph...&threadid=30632
Does anyone has tutorials how to install SAFC in 4 cyl. 99 Galant?
Does any1 has any hints how to install it ??
If so, please post the link.
Check out my ride at:
http://www.cardomain.com/id/djgalant
The only 8g west cost 4g64 Turboed Galant.
The guys at Regulate Motorsports are going to install mine along with the headers.
If you dont want to do it yourself, they would probably do it for around 60 bucks.
Matt
Love,
Matt
Thank U very much for the link pinoy....
Matt, Tony will install it. I am just curius if there is any trick to it, like any hidden settings for our car, or something that might get wrong if you don't set it the way it should be set in our car. If you look at the Apex's manual - you don't see a fricking galant listed there (except for vr4-which is totally different story).
btw, this instructions are really helpfull.
i tried installing my safc myself once with no success. I am still trying to find the exact wiring diagram for the V6 galant. I have all the info for the eclipse sportronic but not galant. and there is a few differences. for example: pin 72 throttle pin (supposed to be yellow) on my car is brown/white
so i am not sure mine didnt work cause of the wrong pin or the ground was not properly connected. i am going to try again this weekend.
BE CAREFUL.....DONT MAKE THE SAME MISTAKE I DID...AND ALLOW PLENTY OF ROOM OF WIRE.....OTHERWISE YOU ARE GOING TO HAVE A HELL OF A TIME SPLICING
GOODLUCK
