Yup, thanks got it,
now i got bigger problem. look at this picture. I know the top is the Antenna, and the bottom is for Remote in right? i am installing Sony Xplod CDX-GT550UI. Do i need some sort of adapter?
http://www.crutchfield.com/p_158GT55...550UI&skipvs=T
https://picasaweb.google.com/lh/phot...eat=directlink
AkA K h O p A r I.
I Am back BitcheZzZ
The smaller one you won't need, It's supposed to be for increased am signal. (I think), Anyway when I did my 3G with infinity left it out and never had a problem, AM reception was good not that I listen to it anyway.
Remote in is for steering wheel controls
BTW that deck you got is pretty sleek, only thing is that the output voltage is only 2V, It is recommended a minimum of 4V when you use the factory amp so there is no engine noise and so you get optimum performance from the amp, but it's just a recommendation doesn't mean it applys to everyone. But if the volume happens to be low at high levels that would be why. Make sure your blue/whit line wire from the sony is connected to turn the amp on so you can have sound.
Ok thanks. I am hook it up tomorrow and let you know how the sounds is. below is the harness i got. I did hook up the blue/white from AMP Adapter to sony adapter.
http://www.crutchfield.com/App/Produ...707003&tp=2977
AkA K h O p A r I.
I Am back BitcheZzZ
Yep from the sony harness to the harness with rca's I dont think the other blue needs connecting. PM me if anything bro. I will be on standby from my phone
Aight, its sounds great. I was not able to the bazel around the HU to go on, cause galant outer shell is little smaller than Sony's
AkA K h O p A r I.
I Am back BitcheZzZ
Ok this picture shows the opening.
and this pictures shows how the sony bazel is bigger than the opening.
AkA K h O p A r I.
I Am back BitcheZzZ
Here is the bazel by it self.
AkA K h O p A r I.
I Am back BitcheZzZ
my alpine was the same way. i just shaved it down until it fit.
I did the same, just shave it till it fits.
2002 ES i4 SOHC Mitsubishi Galant
Sweet.
AkA K h O p A r I.
I Am back BitcheZzZ
all it is, is the trim piece can't get a grip on the radio itself. sometimes you have to trim it, sometimes you can adjust where the screws go in so the radio protrudes out more, or just don't use the trim piece at all. I don't use the trim on mine and just put soft sided velcro around part of the radio and you can't really notice much.
