Thread: Hey Guys New Pics Of Whats Coming Up...Some new pics
Page 24 of 31 FirstFirst ... 14202122232425262728 ... LastLast
Showing results 461 to 480 of 607
  1. #461
    ok just a little update.
    finally got all the parts ready to send the head to the machine shop. should have it back sometime next week. here is a list of the parts i have so far
    -Weisco Pistons
    -Eagle Rods
    -ARP Main bolts
    -ARP Head bolts
    -HKS 272 intake and exhaust cams
    -Brian Crower Titanium Valve Springs
    -Brian Crower Stainless steel intake and exhaust valves
    -ACL race main and rod bearings
    -Gates Performance Timing and balance shaft belts(blue)
    -Fidanza cam gears (red)
    -AEM Hi-flow fuel rail
    -RC 1000cc injectors
    -Zaklee clear upper timing cover
    -Felpro head gasket set
    -Felpro conversion(lower) set
    -New OEM water pump
    -New OEM Oil pump
    -New OEM timing tensioner and idler pulleys
    -New OEM sensors. Cam, crank, coolant temp, temp sensor, others look in good shape.
    MAYBE getting or need to get
    -Skunk 2 68mm throttle body
    -Skunk 2 intake manifold
    -cosmetic or HKS head gasket
    -Performance radiator..not sure on who yet
    anyways here are a few more pics of the parts as they come in.. waiting for UPS to bring ACL main and rod bearings, hopefully coming in this week so i can start building the bottom end.
    BC intake and exhaust valves
    AEM hi-flow fuel rail
    RC 1000cc injectors
    stay tuned as the build is just a few weeks ahead...
    on the other side i made the eclipse look a little better in my opinion. wont be doing any type of modification to this car, as i want to keep it as a daily driver.
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  2. #462
    08-04-2003
    NY
    4,344
    is the felpro gasket MLS???
    99' Galant ES
    4G64/63T
    AEM EMS
  3. #463
    06-13-2008
    Bronx, NY
    2,606
    Good job. Lots of parts.
    SOHC Turbo
  4. #464
    Quote Originally Posted by Stewi View Post
    yes the head gasket is MLS, i might end up using it, since the hks head gaskets run close to $200.
    Fully Built 4G63
    HKS 272
  5. #465
    08-04-2003
    NY
    4,344
    Currently the best headgaskets available for the EVO motor are the OEM MLS gasket and the MLS gasket from PowerEnterprise. Make sure you let the machine shop know your using a MLS headgasket so they can deck the surfaces on a CBN mill to achieve the proper R/A rating. You cant deck them on a regular machine like you would a motor using a normal headgasket.
    99' Galant ES
    4G64/63T
    AEM EMS
  6. #466
    Your Eclipse is perfect!
    "A mile of road takes you one mile...A mile of runway takes you anywhere."
  7. #467
    Experienced TGC Member Galantfan88's Avatar
    12-02-2008
    Carteret & Manalapan, NJ
    1,263
    What is your compression on the pistons? and if it was me I would use cosmetic gaskets...they are pretty good. As for cooling get a Mishimoto radiator for an Evo 8, all you have to do is re-mount the radiator mounts or make your own which is what I did.
    Evo 8 ECU / 5 Speed Swap / Fully Built Forged Motor
    Turbonetics Turbo T31 Stage 3 / RPW Stage 3 Camshaft
  8. #468
    08-04-2003
    NY
    4,344
    Quote Originally Posted by Galantfan88 View Post
    Cometics EVO headgaskets have proven to be the worst option as of late. I know, I think about it alot since I have a cometic headgasket on my engine. When I did the headswap it was the only gasket available for the DOHC conversion, recently AMS started mod'ing stock MLS gaskets to work and Power Enterprise started making them too. The NEW style cometic gaskets are good, but they are also $250, at that point you can buy a Power Enterprise one for the same price.
    99' Galant ES
    4G64/63T
    AEM EMS
  9. #469
    stock compression on the pistons.. i know hks makes thicker gaskets to raise compression but thats something ill look into as i get there.
    as for the radiator i was actually looking into one of those.
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
    or this one
    Fully Built 4G63
    HKS 272
  10. #470
    head is currently in the machine shop getting a valve job and all the works with new valves, springs/retainers, valve locks. should have it back sometime this week if not next week.
    just got quoted $500-600 to do the short block, which includes installation of all new internals, honing of the cylinder walls, balancing of the crank which is crucial, and other stuff. in the coming weeks ill be taking the block to get done and after that hopefully start putting the engine back together.
    Fully Built 4G63
    HKS 272
  11. #471
    06-13-2008
    Bronx, NY
    2,606
    Thanks not bad. Great
    SOHC Turbo
  12. #472
    Lookin great!!!!!!
    No more Galant. Hello G35 and a GREAT BIG HELLO TO MY TURBO! :)
    <><>www.freesurveymoney.webs.com<><>
    Earn easy money, NO you do NOT need a credit or debit card!! Free
    I have proof upon request
  13. #473
    Clean galant and eclipse...gotta be nice to cruise around in either in the miami scenery. Never been to either but miami and japan just seem so cool.
  14. #474
    well finally got the head back from the machine shop...waiting for the bottom end to get finished to start putting it back together.
    Fully Built 4G63
    HKS 272
  15. #475
    nice^ very nice.... are you going 2.0? or 2.4?
  16. #476
    Quote Originally Posted by Galantman03 View Post
    2.0
    Fully Built 4G63
    HKS 272
  17. #477
    06-13-2008
    Bronx, NY
    2,606
    What type of turbo are you going with. You dont think the injector a little big? You will need to rescale them down. By the way nice clean evo head.
    SOHC Turbo
  18. #478
    not quite sure yet...for the first few months im gonna be running the stock evo 9 that i have now, pump up the boost and see what i can get out of it..my goals are 400+...i see many evo guys getting that power with the stock turbo...so we'll see...i have been looking into a gt35r...but thats another story...the injectors will flow more than enough fuel for any type of set-up i decide to throw on there..might have to scale them down but its ok, i know if i ever want more the fuel system wont be a problem
    Fully Built 4G63
    HKS 272
  19. #479
    Get an fp stock replacrment Turbo or a crbd bbkb
  20. #480
    Quote Originally Posted by greddy View Post
    ive been looking into the FP red or black...aiming more towards the red...when the time comes ill see what i decide on.
    Fully Built 4G63
    HKS 272
