Stick with the 2g bar or dimple you exhaust to provide clearance! That the problem with the stock exhaust... mine was custom. Try that before you spend any money!
You could always hose clamp them together and that should stop the vibration!
I got a rear sway bar installed off a gsx. The bar is touchibg my exhaust and its making a horrible vibrating sound. I decided to replace it now heres where i need help. I am curre tly looking at a rear 19mm sway bar for a 2g or go to a jubk yard and buy the rear control arma and sway bar off an 8g. I can get the 2g 19mm for 130$$ and the rear sway setup off a 8g for 140$$ wich one should i get?? Heres the link for the 2g bar
http://cgi.ebay.com/ebaymotors/ws/eB...TM:MOTORS:1123
so why didnt u jest get a GST bar?
quote from peanotations website and sway bar tutorial
Because of all the inherent problems with the 18mm bar, I suggest a smaller bar be used. The GST sway bar traces the rear crossmember quite accurately, and doesn't have all the wierd bends the GSX bar does for its AWD system. This will hopefully prevent the interferance problems and make it easier to bolt down the brackets.
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
yea i saw the tutorial the thing is my piping is not stock its a lil bigger than stock thats why it pushes the pipes a lil further. and now that ive tried the 18mm i dont want to go to 15mm. so i started thinking if the gst bar had a good fit becouse the lack of awd bends i guessed a 18mm aftermarket bar for th gst would be a good option
the gst bar is fine. are u going to track the car or autocross it? ive had the GST 15mm bar for 3 years and its great.
id dent in the pipe a little to make it clear as i had to on my exhaust to clear my lower strut tie bar
2014 Lancer Evo GSR
i dont do either i just drive around mostly highway and i like to take on some twisty roads once in a while as fast as the car can just push it to the limits
2014 Lancer Evo GSR
I would have to buy that one still so why not buy it 18mm? i would go with 8g but its almost same price prices here in pr are high on junkers
what about the one addco one that mko has for sale?
https://www.thegalantcenter.org/showthread.php?t=45801
u were talking about changing the bar out, or you could make the exhaust go unger the rear cross member and that solves it as well
2014 Lancer Evo GSR
