we dont have that engine in our Galants in the US where are you from? may have better luck posting in the international members section....
sounds like a 4g63 though which should be easy to turbo
SEARCH!!!
Hello I'm really sorry for posting, Instead of using search. but first of all.
I tried to google to find out what engine i have.
01 Galant Sport 2.0 manual. SOHC 16 Valves so whats the code for this engine? I.e. 4g63 etc ? And does Garrett t3 turbo unit. fits to that engine?
What you could tell about that Garrett t3 turbo unit.? thank you in advance.
SEARCH!!!
2002 5spd swapped
under construction.....
From UK mate. I could post Picture of it. If that changes anything.
Uploaded with ImageShack.us
That is definitely a SOHC 4G63
So turbochanger easily goes innit? what about that turbocharger I mentioned above? garrets?
I found this turbo http://www.gumtree.com/p/cars-vans-m...-unit/77550032 . what do you say?
read some of the forums about boosting (adding turbo)on here this site has endless info on all things galant.
makes me wonder now if he could do a dohc swap from a evo like us??? would all the turbo parts fit from the dohc 4g63 hmmmmmn?
2002 5spd swapped
by that saying you mean Whole Engine Swap? or just some of EVO Dohc 4G63 Engine Parts?
Im pretty sure the evo head will swap over. Depending on the engine orientation will give you what evo head you can swap.
I mean just the engine parts i think the evo 8 would work just like the 4g64 sohc the timing belt is on the left side the same so i think it would work but you should do a bit more research to find out. but take a look at this anyway
https://www.thegalantcenter.org/showthread.php?t=38229
there is another thread too that i may post when my search function is working properly
2002 5spd swapped
basically if you want to turbo it do some research and figure out the best set up for you im thinking almost all the dsm parts from the dohc 4g63 will fit so look into that if you dont want to swap heads.
i never said anything about using 4g64 parts just swapping a dohc head from an evo which is a 4g63t
2002 5spd swapped
