Thread: ECU reflash Dyno Results.
Page 2 of 2 FirstFirst 12
Showing results 21 to 25 of 25
  1. #21
    Im interseted in the reflash but does it work only on ralliart galant
    Mine is gts 2007 3.8l
  2. #22
    they can flash any 4g69 or 6g75 engine. those are the only two engines used in the 9th gen galant. mivec or not.
  3. #23
    infliction!!!!!!!goood ton see you here dude!!
    by chance do you know how much it go for reflash??
    8th and 9th gen galants
  4. #24
    Last I heard from Mike it was around 500$CAD.
  5. #25
    hey killa. i told you where you could find me. this is the only thread im subscribed to on here.
    and mon's figure sounds about right. but right now he's trying to focus on the diy tunes thru the internet. and setting up shops around the US with everything they need to do the reflash
