Thread: Post What You Did To Your Car or Bought Today!
Page 83 of 538 FirstFirst ... 337379808182838485868793133183 ... LastLast
Showing results 1,641 to 1,660 of 10744
  1. #1641
    Quote Originally Posted by 8thLS6 View Post
    Like the state of your car kouki and dronesurfboards I've got the simply clean sticker lol. Hey conjee how hard was it to install the horns, its an idea I thought about but wonder if my stock vents will cover them up too much since I have an 02, and 02/03's have less open area. Don't plan on changing the grill one of the things I love about the car. Are they are they louder? Its obvious I want them soley for looks lol
    The supertones were not too dificult to install. I extended and used the original horn wire to power the supertones, then connected the supertone ground wire to the vehicle metal body. I am not sure if it will fit an 02-03 vent, but for me the fit was tight. I ended up mounting the supertones to the upper headlight bolt. The sound is pretty loud far better then the stock. The 300hz horn sounds really good, the 500hz, not so good. You can get by with just 1 horn connected, but two is always better.
  2. #1642
    05-14-2010
    Coachella, CA
    5,954
    Quote Originally Posted by jimmy_o2 View Post
    we need a pic from outside of the car with lights on
    Ok check back later tonight, I will try to get a few.
  3. #1643
    05-02-2008
    Hacienda Heights, CA
    3,012
    Quote Originally Posted by dronesurfboards View Post
    My license plate frames came in today.
    Since the Illest frames are discontinued, i searched around and got these for both cars.
    btw so cal people...anyone going to wekfest in June? it would be cool to see the OC and LA peeps since i keep missing MOD.
    that plate frame is pretty dope. is it the one in Long Beach your talking about?
    Quote Originally Posted by IVORY_G View Post
    never pull out, always squeeze inside! LOL!
  4. #1644
    ordered exhaust, my hood is coming, injectors, and Wideband gauge... just need to get ahold of deeznutz so I can get the finishing item! Get on MAN! lol
  5. #1645
    Quote Originally Posted by Galantman03 View Post
    I smell a beast coming! lol
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  6. #1646
    oh... a small one... till january ish... then its full blown... I think lol... I'll be buying parts and having them delivered to my rents place when I'm halfway around the world lol. Hows the proccess coming? You getting done?
  7. #1647
    She's getting there. Body work is finally done, wheel wells are a Pain on the galant. There's that little thing next to the rear door that is about 1/4 of an inch wide that is part of the body line. I think I did it like 5-6 times and am finally happy with it.
    Rusted bolts can kiss my ass too. I had to drill a couple out that broke flush and re-tap them so I can stick new bolts back in. Got my exhaust up and headers bolted back together. I have to bleed the brake system and clutch lines, hook up the electronics and cap off two of my 02 sensor holes. ( My old g had 4 sensors and this one has 2. GO FIGURE! ) After that she'll be started up and moved over to another garage bay for paint.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  8. #1648
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    Worked on my 3G & found a leak in my a/c system on the high side, Got my V-Led brake light bulbs & found out that the G got impounded & I got 2 tickets along with that while I was in skool...
    Sent from my BB Curve 3G using Tapatalk.
    - Chris -
    DRL Delete
    | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
  9. #1649
    I thought you sold the g? ^^^
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  10. #1650
    11-29-2009
    Chadds Ford, PA
    2,768
    i topped my G out trying to outrun the snow storm cause the g is in summer mode and barely got home -_-
  11. #1651
    11-18-2009
    Buffalo, NY
    1,758
    I was suppose 2 but the guy that wanted it never contacted me & I tried getting in touch with him & no answer
    - Chris -
    DRL Delete
  12. #1652
    12-13-2010
    Brooklyn, Maryland
    4,638
    What's the top speed?
    -Greg
  13. #1653
    11-29-2009
    Chadds Ford, PA
    2,768
    Like 124 125ish. Oh I just bought 30 dollars worth of stickers Hahahaha I got a illest, fatlace, shocker, so fresh, chillest and a hoonigan that what I can remember
  14. #1654
    12-13-2010
    Brooklyn, Maryland
    4,638
    Shiiiiiit, them stickers should get u up to 130 lol....
    -Greg
  15. #1655
    11-29-2009
    Chadds Ford, PA
    2,768
    nah thats like adding a super jet the so fresh one ad 10000000000000hp i should qualify as nasa's next spaceship i just need a big ass wing and ill be set.
  16. #1656
    12-13-2010
    Brooklyn, Maryland
    4,638
    LOL true, one must stay fresh, it's a rule.
    -Greg
  17. #1657
    Quote Originally Posted by E_Emerson88 View Post
    yeah on June 5th. going to toyotafest also I think on may 14th also.
  18. #1658
    I installed the heater control motor so no more frickin ac tick, I used one of the tutorials on here to help me out.
    02 Galant GTZ stock
    00 S10 Bagged on 20's Suicide Doors 5 link and control arms, more to come!
  19. #1659
    05-02-2008
    3,012
    im down for June 5th. ill PM you my number so we can meet up that day before hand
  20. #1660
    05-03-2007
    Socal/Central Coast
    3,803
    can't make the one in June, that's RIGHT before my finals. May 14th I'm coming back down for my birthday :)
