Thread: m-rod's 99 GTZ
Page 18 of 54 FirstFirst ... 814151617181920212228 ... LastLast
Showing results 341 to 360 of 1078
  1. #341
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Lookin Good!
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
  2. #342
    looks real good bro!!
  3. #343
    My latest project a few weeks ago. It's funny how much difference that manifold makes on the 6g75.
  4. #344
    12-13-2010
    Brooklyn, Maryland
    4,638
    Is that the 75 manifold? The motor looks good!
    -Greg
  5. #345
    i gotta get that tb! that bay looks sweet!
  6. #346
    looks awesome man!
    Is that a mivec only IM or it's on all 6g75's?
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  7. #347
    you should try and get that 90 degree turn out of the intake tract. it will flow better.
    Jigz-TGCIL Sosick Motorsports
  8. #348
    07-12-2007
    SoCal
    4,632
    Quote Originally Posted by 4g63lover View Post
    I agree, needs a more direct routing of the piping...
  9. #349
    Quote Originally Posted by M-Rod View Post
    bad ass bro!!!
  10. #350
    Thanks guys. yeah its the 6g75 non mivec manifold. I finally got around to swapping it on because the 74 mani has been on since the engine swap over a year ago. thought it would be a good idea to bring it closer to completion.
    I was thinking of cutting the pipe before the bend for that reason but it helps angle it down into the massive hole of fresh air.
  11. #351
    07-12-2007
    SoCal
    4,632
    Something more like this would be more effective and better looking IMO:
  12. #352
    Experienced TGC Member carl3g's Avatar
    03-16-2010
    Maplewood, NJ
    1,290
    Looking real good!
  13. #353
    04-02-2009
    Denver Colorado
    1,447
    You can't go anywhere with the throttle cable unhooked buddy ;)
    3G Eclipse Performance & Development - Denver, Colorado
    www.blackheartmotors.net
  14. #354
    05-03-2007
    Socal/Central Coast
    3,803
    damn, good eye Matt lol
  15. #355
    Quote Originally Posted by SPD_FRK View Post
    lol good eye!
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  16. #356
    I ended up mounting it to the firewall. the picture was about 15 minutes before completion.
  17. #357
    05-14-2010
    Coachella, CA
    5,954
    Very sweet indeed
  18. #358
    04-02-2009
    Denver Colorado
    1,447
    I will snap a picture of Bj's 75 manifold since I have it sitting here at home. The bracket was pretty easy to mount on the manifold with what he did.
    Also, have you made any tuning progress yet? I see you are running the 482 MAF on there, if you haven't...check out the information below for some details on that MAF;
    http://www.galanttuners.com/index.ph....html#msg14534
  19. #359
    Thanks for the info Matt :) I still haven't made any progress on the tuning end. I have way too many things happening right now to give much attention to the car but when I move at the end of the month I'm hopeful that things will change.
  20. #360
    Revival!
    Well since the car is parked for a few months, I decided to start working on it again. Ever since the 75 mani swap I've had this crazy RPM pulsing at partial throttle above 2k RPM. I tried everything I could think of, such as checking all my new vacuum routing, switching to the 75 rear valve cover (because the 72 valve cover hits the 75 plenum) and replacing all intake gaskets. Even Silvertune of c3g was poking around under the hood to see if we could put our heads together and figure it out, then it dawned on him. I had mounted the throttle cable bracket to the firewall due to the excessive length of the cable, but the engine rocking pulled on the cable causing it to open and close. I could've kicked myself. So I've been looking around at work for ways to shorten the cable and behold, I found these on the Help! rack. They share the same 5/16" OD as the original throttle cable end. Problem solved.
    And now the bracket will be bolted to the EGR valve upper bolt. You will need to drill out the bracket slightly since the bolt will not fit into the bracket without modification. But this is where it will mount.
    The other ongoing project isn't very far from moving along as well. Only the fenders and condenser are left to remove before grinding the radiator support off. This will be updated soon as well.
Tags for this Thread
