you can use the clutch kit if you are 5 speed. 750 injectors can be used once you are turbo and able to scale them in the ECU, not sure on the cam gears, and also not sure on the springs or retainers.
i sold my 2g turbo eclipse and i still have a few parts and im wanting to know if i can use them on my galant??? i am doing the kia dohc swap too, i have adjustable cam gears, 750 injectors, and a new clutch kit, bc springs and retainers... thanks for all the help....
Thanks!!
That's a 3g trans right?
Yes, 3g trans, you'll need the 2g starter and starter plate, 2g flywheel and 2g flywheel bolts in order to use the 2g clutch kit you have. Injectors yes, I think you'll need a resistor box if they are low impedance. Don't know anything on the rest of the stuff.
4g64T 5spd
Thanks for all the info!!
Thanks everyone for the info, now what about the springs and retainers, cam gears, and I forgot I got a 255 fuel pump....please let me know if I can reuse these parts....
From Our How To Turbocharge by jonathan:
Said writeup:You can use a fuel pump for a 1995-99 eclipse turbo models made by walbro or whoever but make sure its 190lph or more or atleast the stock evo level. Tearstone.com has a great writeup on how to fit these fuel pumps. Essentially you trim the fuel filter sock at the bottom to allow the pump and sock to fit in and the fuel pump housing to close perfectly.
http://tearstone.com/shop/Fuel-Pump-...us/Galant.html
4g64T 5spd
