This is what you would want for aiming you lights:
It's hard to see, but both headlights are pretty much on the exact same horizontal level in this pic, both lower steps lined up and both higher steps lined up, when driving they'll look like one beam instead of two.
I know you have aftermarket lights, but try to get them as close to level with each other as possible, the blended light will be brighter and give you more distance vision. Good luck, you've got great progress so far, I need to do this myself!
-Greg
So I'm mounting the FX-R directly to the housing to eliminate shaking from the reflector having too much stress on the OEM screws. Weta, I'll keep you updated.
I used some medium density foam I cut into strips and put some on the top and bottom of the reflector, basically between the housing and reflector to help with the vibration or bouncing that may occur. It still allowed for adjustment and I haven't had any issues. It may have been fine, I just did it because I didn't want to have issues or anything come up down the road.
http://www.hidplanet.com/forums/show...869#post420869
It can be done. haha.
I'm confused, here it says the top is the FXR and bottom is D2S, IMO the bottom has more light....FX-R (top) vs Mini D2S (bottom). You decide which one is better.
This is misleading. The bottom has more light because it doesn't have a foreground limiter. However, that is up against a wall. On the road, that translates into a lot of light right in front of your car, which will condition your eyes for more brightness, closing your iris and decreasing your distance vision. Plus, look at the top one, and look at the "hotspot" right at the steps, just below the cutoff. That brighter region is gonna translate to more distance light, and since it's right at the cutoff on those bi-xenon projectors, when the shield flips down for the high-beams, they're gonna really be bright. To truly compare the superiority of the FX-R over the Mini D2S, one needs either more distance from the wall, or simply look at some road output shots.
50' shots:
FX-R Low Beam
Mini D2S Low Beam
FX-R High Beam
Mini D2S High Beam
Road Shots, the real decider:
FX-R Low
FX-R High
Mini D2S Low
Mini D2S High
FX-R's all day!
Edit: I don't think the exposures on the road shots are the same, those FX-R's are incredibly bright in those pics, and the D2S's are rather dim, but according to HIDP members, that's the case, misleading exposures or not!
-Greg
LoL @ last pic ! those bulbs have some seating issues !
I did see the hotspots in the FXR's, and the pictures did throw me off. I did get it, but rather misleading without multiple shots like the ones you posted up Gregs. If and when I do a retro I'm going to go FXR's or not at all. LoL.
