TGC Regular
Exhaust Heat Shield Bolt size and Threads?
Could someone please tell me what size threads are on the four bolts that hold the exhaust manifold heat shield on? Also, what are the length of the bolts? I need to remove the shield so I can make a custom one but all four bolts are rusted solid so I can't get them out to get their size. Thanks in advance.
You can get them out, try PB Blaster a good soaking should do it.
TGC Regular
I finally got them out. It took a torch, some seafoam "deep creep," stripped bolt extractors and a 16" breaker bar.....jeezus!
Just for reference, the bolts are M8 X 1.25 X .50"
