Yeah the gs cams are the more agressive cams.They are an upgrade compared to the other two.
Does anybody have the specs on the dohc cams? I am installing valves today but want to put the most aggressive cams in with parts I have. I am using a 1g head with a modded distributor and staying na. I have or can get locally and cheap a set of GS cams, 97 Sonata cams and 1g na cams. I am thinking the GS cams are 264's and likely the best ones to go with but wanted to double check first.
The G stamped cams are more aggressive 264/260 I believe, but they are rare and hard to find.
Here's more info on the GS specs.
https://www.thegalantcenter.org/showthread.php?t=13984
According to that info the exhaust should be a h or g but both of mine look like k up front close to the cam gear.
The GS cams are somewhat like a weak HKS 264/272 cams or borderline HKS 264 cams but with very small lift.
1994 GS FYI
DSM/CSM Manuals
on my cams they are L stamped cams. i cant find anything on them
2014 Lancer Evo GSR
1996 Galant S 5 Speed Turbo
Use a digital caliper and measure the cam lobes. If the cam height falls in the catagory of the GS cams then the duration should be the same as the GS cams.
Or just purchase some DeltaCam 264/272 cams.
1994 GS FYI
DSM/CSM Manuals
These L cams are from a 94 GS so I think they would be around there but I didn't know if it meant anything specific
2014 Lancer Evo GSR
could be a revision version..idk
1994 GS FYI
DSM/CSM Manuals
the lobe height of them are
intake- 1.390 inches
exhaust- 1.371 inches
2014 Lancer Evo GSR
looking at the cams again, my cams have the L stamped where the 2g cams i have say c but on the other hand there is a little H so maybe they are just H cams then
2014 Lancer Evo GSR
seems a bit worn, the cams: about 9.2mm lift on the intake side and 8.3mm on the exhaust. appears to be the GS cams.
1994 GS FYI
DSM/CSM Manuals
with my measurements and using a rocker ratio of 1.7:1 i got a lift of 8.85 intake and 8.25 exhaust. i will remeasure the intake to make sure as the exhaust is close enough
after a closer look and not taking measurements in a hurry and inaccurately here are the specs on got
Cam Lobe Height
Intake-1.400 inches - 35.56 mm
Exhaust- 1.375 inches - 34.93 mm
Cam Lobe Width
Intake- 1.180 inches - 29.97 mm
Exhaust- 1.180 inches - 29.97 mm
Cam Lift
Intake- .220 inches - 5.59 mm
Exhaust- .197 inches - 5.00 mm
Valve Lift using 1.7:1 rocker ratio
Intake- .374 inches - 9.50 mm
Exhaust- .335 inches - 8.43 mm
2014 Lancer Evo GSR
looks good.
1994 GS FYI
DSM/CSM Manuals
mystic, do you have any specs on what your stock ones were to compare?
2014 Lancer Evo GSR
1994 GS FYI
DSM/CSM Manuals
Thank you very much. It's always good to have an idea about the cams in there now before I mess with them. So I should be around the same duration with a little more lift from what I see there. Thanks again
2014 Lancer Evo GSR
Good. The 272/264 I have now required a bit of a heavy foot. If I went 272/280, it would be a bit unstreetable.
1994 GS FYI
DSM/CSM Manuals
