stroked 4g63 i beleive
Found this posted in our local 8g thread here in the PI but nobody seems to know it's specs...
All I know is that it's a Time Trial Car...but to what err I don't know...
I'm hoping somebody here can help and provide it's specs and post some info about it.
Thanks in advance!
I believe it has a 4G63 power plant. Other than that, it looks like could scoop snow during winter months :)
Supposed to be pushing 800hp.
http://the-sun.on.cc/channels/car/20...5622_0010.html
http://the-sun.on.cc/channels/car/20...22_0010_1.html
I do not have google chrome on this computer so i cant translate it but here is some specs
There is some more picts on this page
http://www.trinituner.com/v3/forums/...c.php?t=158707
Reelax's car is even on there
Wohooo!!!! Thanks for the links
JUN VR4 conversion specifications
Man: Can Aberdeen 23/06/2003
Engine:
JUN 4G63 engine 2.2 Kit (85.5mm forged piston, connecting rod, 94mm stroke crankshaft, and strengthen the crankshaft bush, 1.2mm plate top mouth, compression ratio 8.4:1)
JUN Stage2 272 degrees 10.8mm Camshaft Kit
JUN Valve slingshot
JUN Titanium Valve pie
JUN strengthen the belt (all cars)
GReddy TD06 25G Turbo
Cusco Twin Plate strongly sub-
80mm Butterfly cover
1,000 cc Sprue × 4
Cooling system:
GReddy Oilcooler Kit × 2
ARC Intercooler Kit
SARD reserve kettle
Koyo radiator
Cold water tank
Special fan
Smoke exhaust system:
JUN special titanium dead air hose
JUN special banana dead air
K & N PC965 air filter
GReddy Type R Racing Blow Off Valve
Suspension:
JUN Spec Endless Zeal suspension stirred teeth
Swift ID60 22K slingshot
Strengthen the equipment:
Qiantaxiangba
Nine-style roll cage
The entire vehicle to strengthen the bottom bear
Brakes:
AP Racing six piston calipers (front)
AP Racing front and rear braking force distribution control
Brembo two-piston calipers (rear)
Evo. Ⅵ brake master cylinder
Wheel combination:
SSR Type C wheels (18 × 9.5 +30 Offset)
Yokohama Slick Tire (250/650R18)
Electronic equipment:
GReddy Mechanical Plumbing valves
GReddy Speed Limiter Cut
HKS F Con V-Pro PC
HKS Twin Power
Max Racing Electronics dashboard
Other equipment:
JUN engine oil cap
JUN 3D GT wing
JUN surrounded the whole car
JUN head
5 Zigen ring
5 Zigen gear stick head
Corbeau bucket seat
Sabelt four-point seat belts
Best motoring has a video on it. I remember seeing it on the front page with a evo!
