Thread: Post What You Did To Your Car or Bought Today!
Page 142 of 538 FirstFirst ... 4292132138139140141142143144145146152192242 ... LastLast
Showing results 2,821 to 2,840 of 10744
  1. #2821
    i thought this was a good price for the evo 8 ecu ^^^ Not sure if its an auto or manual though.
    http://cgi.ebay.com/ebaymotors/Mitsu...c#ht_500wt_975
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  2. #2822
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    Quote Originally Posted by keith6110 View Post
    Someone correct me if Im wrong but I don't think a ACD ECU is the same as the Evo PCM, so the thing on that link is not whats needed.
    edit:
    ACD(ACTIVE CENTER DIFFERENTIAL) module.
    4g64T 5spd
  3. #2823
    08-04-2003
    NY
    4,344
    Correct the ACD module is totally different.
    Also, in the U.S (not sure about overseas) the EVO was only offered in a manual transmission configuration.
    99' Galant ES
    4G64/63T
    AEM EMS
  4. #2824
    Bought another set of beltpads... =) Mitsubishi!!
    Thomas R aka Valpen
    CEO & Eventmanager
    Mitsubishi Club Sweden
    Former New yorker....
    94-10 60th Ave
    113 73 Elmhurst, NY
    School PS13 - then moved to Europe
  5. #2825
    That's a good price for the ECU, to bad they are ACD =[
    TURBO= in the making.......
  6. #2826
    06-16-2010
    Fort Mill, SC
    2,282
    Picked up a set of D/S rotors and pads :)
    -Andrew
  7. #2827
    Quote Originally Posted by Stewi View Post
    I did not know that. Glad some one corrected me and I didn't steer some one in the wrong direction...
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  8. #2828
    Senior TGC Member Skyforger's Avatar
    05-05-2011
    Medford/Long Island, NY
    2,135
    Quote Originally Posted by DTP View Post
    DO NOT use ceramic pads on them. I learned that the hard way. Use a high quality semi-metallic.
    Sucky thing about those, you can't resurface them either. :/
    -Chris-
    2003 Mitsubishi Galant ES 2.4L SOHC: "Octavia"
    2005 Honda Accord EX-L Coupe 2.4L DOHC
    Quote Originally Posted by XxGiRLaNT06xX View Post
    From the looks of the girl, her face isnt that great.. nothing a paper bag couldnt fix... amirite?
  9. #2829
    ^um, yes you can, I do it all the time when I get new pads....
  10. #2830
    05-05-2011
    2,135
    Quote Originally Posted by greddy View Post
    You can't do pad slaps with ceramics, the pad compound is too hard. The small groves left by the old pad, the new ceramics aren't going to "mold" to the groves, leaving pockets of hot air, and giving you a bad brake pedal, and brake fade is pushed too much.
    At least with the semi-metallic, the pad breaks in and takes the shape of the small groves already cut into the rotor.
    Me personally, you're better off with blank rotors with a high quality pad. Better life and you can give them a cut if needed.
    -Chris-
  11. #2831
    If you say so man, my galant's brakes take abuse that 98% of the people on this forum haven't experienced, and I swap pads in and out constantly, using a variety of different compounds. I also have my rotors turned regularly. Never had a problem with grooving or what not, and they're drilled and slotted.
  12. #2832
    05-05-2011
    2,135
    I dunno if you do Auto-X or road course racing often, then I could see the need for a slotted rotor. But just for street use, you're better off with blanks. But that's just me.
    On a lighter note, you still have that lip handy? :D
    -Chris-
  13. #2833
    06-16-2010
    Fort Mill, SC
    2,282
    We both AX :)
    I see what both of you are saying... But I already have a set with ceramics, and they've held out fine.
    I abuse the piss outta my car at times. The only problem is that these rotors are warped to shit. Hence why I picked more up! But I paid almost nothing for the new ones, so no worries.
    Sent from my iPod touch using Tapatalk 'cause I'm awesome...
    -Andrew
  14. #2834
    It is a matter of reducing gas build up between the pad and rotors. That is what brake fade partially is...gas build up and lack of proper venting. Anything metal (wood, or many other materials for that matter). Can be turned or machined, this includes slotted and drilled rotors. The tendency is though that you burn through lather bits more, and are better off on a more substantial brake lather than what most regular repair shops use.
    Now carbon ceramic rotors aren't turned, those are a different animal altogether. Also a reason a brake job on a Ferrari Porsche or similar costs $6000 (or more).
  15. #2835
    I do road course events 2-4 times a month, which is why my rotors are slotted.
  16. #2836
    TGC Regular Redhaze's Avatar
    10-02-2010
    North Carolina
    774
    Tried to get a inspection but i need stock non tinted tails and stock headlights with reflectors..
  17. #2837
    05-05-2011
    2,135
    Plasti-dipped the JDM mirrors, pics later on.
    -Chris-
  18. #2838
    Quote Originally Posted by Redhaze View Post
    Buy a set, put them on. Then swap your old ones back on until next year or whenever your next inspection is.
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  19. #2839
    10-02-2010
    North Carolina
    774
    Thats the plan looking around the forum and ebay for some cheap ones
  20. #2840
    I went to the yard and luckily they had some halfway torn apart ones so with my super human strength lol i ripped the rest of them apart and tore out the reflectors. Lady let me have them. So im going to bake my original ones and put the corner back in them. Beats paying 90 for a set
