All those have been answered, but its alot of searching so...
You need a 94 Galant GS timing belt, it came stock with DOHC 2.4, so that belt is the right size.
No, you don't need a evo water pump, your stock one will work fine, if you use an evo 8 block or 4g63t, you need the adapter plate if you running a 2.4 water pump. So your good there, use your stock water pump
As far as the diagram, I have no idea of the top of my head, best bet is to search. IF you don't want to use resistors you can use high impedance injectors
