Well here is some questions...does the engine crank over at all? If not than see or hear if you hear a clicking sound coming from the starter and if not than it could be the starter or relay itself...or could be battery. If anything take out one of the spark plugs and have your father look down the spark plug hole into the cylinder while you turn the battery power on so you see if the injectors primes the cylinder. Another thing is that since you have the back seat out try to listen very carefully and when turning on the power that you hear the fuel pump. Could be crank angle sensor thats gone bad...it shouldnt be that hard to find out the problem. Take your time and do these steps one by one. Good luck my friend and hope that helped.
