yes, but it requires you cutting off the back brace from the front chassis of the middle piece... which involves a high powered dremel with a metal cutting bit.
i want to put a new grill in. but i have 2 pieces. is there a way i can cut the piece in the middle out that is connect to the front bumper and put a straight mesh grill in?
2002 ES i4 SOHC Mitsubishi Galant
