Thread: Post a pic as your car sits now....
Page 1143 of 1457 FirstFirst ... 143643104310931133113911401141114211431144114511461147115311931243 ... LastLast
Showing results 22,841 to 22,860 of 29136
  1. #22841
    Quote Originally Posted by Bonez View Post
    G looks good!
    Eclipse GT 5 spd swapped
    Rotor Glow Galant
    Daily Galant
    OZ Edition Eclipse
  2. #22842
    Quote Originally Posted by E_Emerson88 View Post
    when did you get a Dolphin Bumper Darren? we should have a meet soon
    socal of course...
    http://vids.myspace.com/index.cfm?fu...ideoid=2799274
    A filipino's number one dream is to own a car before anything else. In the philippines, most private car owners consider their vehicles as an extension of their home but with one differrence: a home is where his wife cooks while a car is where his girlfriend builds a fire. Hmmm...
  3. #22843
    good job bonez! looks good. i got one too from cali, just need a few more items for new facelift
  4. #22844
    These are the 19"s I'm not sure of the offset but if any of y'all can help me to know what size spacer I should get . There tenzos not sure what name rim it is I bought them used off a friend 19x8.5
    Can you size down your sig please? Thanks, Admin :)
  5. #22845
    They are Type M's.
    I can't imagine you'd need a big spacer, probably 5-10 mm
    But I can't be sure unless I know the current offset.
  6. #22846
    what wheels are those? They look like my konigs
  7. #22847
    Sorry not the best artist
  8. #22848
    12-13-2010
    Brooklyn, Maryland
    4,638
    I got it fine, spoke design isn't sharp enough, causing a rub^^^
    -Greg
  9. #22849
    Does it just barely touch when the wheel is all the way on? Or is it hitting before the wheel is even on all the way?
  10. #22850
    How would I figure out the offset ...would it say it somewhere on the rim?
  11. #22851
    It's hitting before it actually meets the hub
  12. #22852
    Found it.....
    I have the 19x8.5 5x112/5x114.3
  13. #22853
    You probably need 10mm, but that's just a guess, do you know anyone who would let you borrow one?
  14. #22854
    So I have a 45 offset, I'm going to get the adapt it spacer that bolts ontO factory lugs and gives u five new lugs, so what do u think guys?
  15. #22855
  16. #22856
    05-03-2009
    Aguadilla, Puerto Rico
    1,465
    1 year ago waiting for a alignment:
    Today waiting for a alignment:
    At another aligning place since the machine got damaged on the place I took the above pic LOL..
    4g64T 5spd
  17. #22857
    Member Bonez's Avatar
    01-14-2003
    West LA, Cali by way of PG County, Maryland
    200
    Quote Originally Posted by keith6110 View Post
    G looks good!
    Quote Originally Posted by BILLET View Post
    I appreciate it fellas. I need help with the fogs though. I need a wire harness to hook them up. Any recommendations??
  18. #22858
    cleazy, if you need spacers, get like a 12mm, 5x114.3->5x100 adapters
    (assuming your wheels are multi-PCD 100/114.3)
    now i know you're thinking thats odd, but, its solves two problem: needing a bolt on spacer and having to grind down your oem studs if they're too long
    that way you can get the spacer
    the wheels now bolt to the 5x100 PCD
    and your stock lugs poke through the 5x114.3 holes so you dont need to chop them off.
  19. #22859
    wow that was quick! looks good bro!
    Cali: Sig 3/28/2011
  20. #22860
    You are here entirely tooo much!! IVORY_G's Avatar
    07-12-2007
    SoCal
    4,632
    Looks good! Where did you end up getting your paint done at?
    JDM Zenki Conversion
    Lazy hands make for poverty, but diligent hands bring wealth. (Proverbs 10:4 NIV)
Tags for this Thread
