new hids 6&3k
[IMG][/IMG]
tryed some 3d c.f vinyl on the gas cap!
[IMG][/IMG]
Installed an hid relay harness inside the fuse box ill post a how to later with pics
HTC EVO 4G
MODS
5 speed swap
Eibach Pro Kit on GR2 Struts
Cold Air Intake
Outlander Intake Manifold
6G72 V6 Throttle Body
6G72 V6 Fuel Pump
Axle Back Exhaust (ebay)
Evo Fuel Rail
Evo Radiator
Rear Disc Swap
Prothane Motor Mount Inserts
new hids 6&3k
[IMG][/IMG]
[IMG][/IMG]
gas cap looks good
^ X2 but like i said on FB, get that yellow film
just wait for it to break in before you decide, because they will get deeper and more rich in color
Ah spent some time with my car, the laptop, some wifi.........dont think dirty now haha, and the tactrix. Did some latency adjustments to try to bring the stft down, but got frustrated since the ECU hasnt cycled yet, I need to go do some driving.
Inner and outer tie rods...and hopefully alignment soon to fix tire wear
Oem bulbs are the only ones to be trusted when it comes to projectors, mainly optics. See, oem bulbs are more than likely to be straight, where as rebased have a greater chance of being not straight. When it comes to the optics of projectors, the littlest error can produce a bad cut off or a dark spot.
Am I making sense? Lol
Just finished buying the ss lines for the brembo caliper (front) install tomorrow. Hopefully I'm going to have my girlfriend assist me with taking pictures, so I can do a write up.
I know exactly what you mean. No newb here, I was mainly referring to cost. I also went over to hidplanet and did a bit of homework and now they have me thinking twice about aftermarket kits. LoL.
In reference to the example you gave about arc positioning, on the Tahoe/Yukon forum I go on from time to time, one of the members had a bad experience using eBay projectors with a PnP kit, he said the output sucked and posted pictures of drastically affected cut-offs and dark spots.
I replaced the neutral safety switch, hoping it was the fix my car needed to start. No such luck.![]()
