Thread: Post What You Did To Your Car or Bought Today!
Page 192 of 538 FirstFirst ... 92142182188189190191192193194195196202242292 ... LastLast
Showing results 3,821 to 3,840 of 10744
  1. #3821
    06-13-2008
    Bronx, NY
    2,606
    TDM installed Front and rear Poly inserts. Let the vibration begin.
    SOHC Turbo
  2. #3822
    Just ordered de moldings from the dealer...b here Friday...freezing in NY and every time I go in and out of gear I'm hearin metal on metal...gotta change my tranny mount but if I do it I'm gonna change crossmember mount and back roller...changed pass. Side already, it's just too faqin cold
    Can you size down your sig please? Thanks, Admin :)
  3. #3823
    ? For u isaurio if it's only a DD why would u wanna provoke vibration issues and poly's are know for vibrations? Pros...cons?
  4. #3824
    06-13-2008
    Bronx, NY
    2,606
    lol. The power of 5 speed. The 4cly has so much low end torque that you feel the whole car move back and forward. I loose power with the oem mount. Is not that bad is only when you go below 1000RPM on take off. I have to get use to to to start at 1200 rpm. Also with that torque the oem mount will go in days. I need also the poly inserts to settle and break it in.
    SOHC Turbo
  5. #3825
    ^^^^That's because the stock mounts suck ass cheaks and f them up in just a few months. You get used to the vib after a wile and don't notice it as much.
  6. #3826
    Experienced TGC Member Rach3T8G's Avatar
    11-18-2009
    Buffalo, NY
    1,758
    ^ Hmm maybe i should invest in poly mounts. Anyways, drove her 330+miles to NYC & once i hit PA, she didn't want to do anything below 80mph ;)
    - Chris -
    DRL Delete
    | 6K HIDS | AUX Cord Wired in RF Head Unit | DC Sprots CAI | OBX Longtube Header | Aero Turbine 2540i Muffler
  7. #3827
    06-13-2008
    Bronx, NY
    2,606
    ^^lol
    SOHC Turbo
  8. #3828
    Sold my 2g today :( mula for new G :)
  9. #3829
    11-18-2009
    Buffalo, NY
    1,758
    Lose-Win situation!
    - Chris -
    DRL Delete
  10. #3830
    ^^^ pretty much I just got tired of pulling myself out because it sits so low and I haven't driven it in months besides that 420a was poopie...
  11. #3831
    due to people telling me i should anyway, i removed my balance shafts
  12. #3832
    Put in de black moldings
  13. #3833
    08-08-2004
    Las Vegas
    2,098
    Quote Originally Posted by QnzMostWanted View Post
    did you use the oem stubby shaft with the oil groove cut into it?
  14. #3834
    Does anyone know which mishimpto rad. Fits 8gs and which hoses work wit that rad to 6g engine.?
  15. #3835
    11-29-2009
    Chadds Ford, PA
    2,768
    Quote Originally Posted by cleazy123 View Post
    Its the eclipse v6 one but if you are automatic dont use it
  16. #3836
    Quote Originally Posted by underated View Post
    yep
  17. #3837
    Oh ok...cooling lines....there are no a/t cooling lines right?
  18. #3838
    u can use it if u add an external tranny cooler, most aftermarket radiators dont have the line for the transmission coolers
  19. #3839
    Get a tranny cooler out of a Ford bronco I recommend this one ... wait for it ...
    Me I'm a lil of both
  20. #3840
    The cooler is laminar flow so the fluid separates and flows criss cross through the fins
