I will recommend getting the actual knock sensor wire since is heavily shield from outside interference. You could get it from a v6, eclipse manual, or evo. I'm using the evo plug with the pig tail works 100% stock. Dion is doing the swap, we will write a tutorial how to install on pcm. The only hard part is that port/pin 90 needs to be open/enable with thing the rom.
