Well, depends on the camber, and offset. If you rolled and slightly pulled the rear renders you could easily tuck a 19x9.5 +30 with -2.75* camber, on a 225/35R19. An 18x9.5 should actually allow for slightly more clearance to the suspension, so as much as a 18x9.5 +35 with not more than a 225/40R18 should tuck, again with a roll and mild pull.
