Thread: 7g(97/98): JiPs 2g ECU Swap tutorial.
Page 3 of 3 FirstFirst 123
Showing results 41 to 59 of 59
  1. #41
    08-13-2008
    Waterbury, CT
    3,331
    You have a map sensor but a 1g head and intake manifold so there is no spot for it without a weld on adapter. The 4 wires on the cam angle sensor are for the crank and cam sensor built into one. Magnus motorsports has the wiring diagrams for a 1g CAS in a 2g
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  2. #42
    Moderator mko's Avatar
    09-20-2007
    Sea Isle city, NJ
    4,098
    You can use 97 sonata MDP sensor. Its not mounted on the manifold and it only needs a vacuum line. Its Mitsu made and the plug is the same as 7g.
    Just search in all the threads that Ive started and youll find it.
    Can you please type in understandable English? Im having hard time following what you're trying to say. Its the tutorial forum after all.
    Build Thread
  3. #43
    i know i got the 1gin2g pdf. But what I'm asking the CAS rewire in these pics.
  4. #44
    09-20-2007
    Sea Isle city, NJ
    4,098
    Are you going to use you stock crank sensor or are you going to use the crank signal off the 1g CAS?
    pin 1 1g CAS goes to BRN/GRN wire of the distributor plug (Cam Signal) pin 68 of ECU
    pin 2 1g CAS goes to the crank position sensor harness if you use it, if you dont then leave it alone
    pin 3 1g CAS goes to BLK/WHT wire of the distributor plug (+12V)
    pin 4 1g CAS goes to BLK wire of the distributor plug (ground)
    Build Thread
  5. #45
    Thanks everyone i be out with the flu for the past week so my dad did me a fav and got me a full uncut 2g i think it was from auto. i will take pics before i put it in.
  6. #46
    08-13-2008
    Waterbury, CT
    3,331
    You can't swap in the full harness as it is too much work. Rewiring the fuse box and stuff. More wires is the last thing you need
    2014 Lancer Evo GSR
  7. #47
    just the engine harness.
  8. #48
    08-13-2008
    Waterbury, CT
    3,331
    Quote Originally Posted by XXL4G64 View Post
    The fuse box is part of the engine harness.
    2014 Lancer Evo GSR
  9. #49
    Quote Originally Posted by Galanttuner10 View Post
    Anyone use a 2g harness in there swap before really need help.
  10. #50
    09-20-2007
    Sea Isle city, NJ
    4,098
    no its not.
    Build Thread
  11. #51
    Is this right or wrong
  12. #52
    Does anyone have a pic of the 93/94 DSM black top cam sensor mated to the Galant Distributor?
  13. #53
    As far as I've found only a few people have done it there's a really long thread on the subject search for...hmm I think the topic was vice versa distributor into a dohc head .....sorry ADHD kicked in I'll dig around with you see what we can find
    Me I'm a lil of both
  14. #54
    Thanks, that would be great! I was going to pm Seth but it looks like he hasn't been on since April. Also I'm looking to stay SOHC.
  15. #55
    08-13-2008
    Waterbury, CT
    3,331
    Pretty sure the whole tutorial is about staying single cam by using the stock distributor. If you are staying single cam the first post is all that really pertains to you
    2014 Lancer Evo GSR
  16. #56
    I was hoping to find pics. Not sure if any machine work or aluminum welding is needed. The OP just says to mate a black top cam sensor to the stock distributor once all of the guts are removed. My plan is to get the two parts here and see if its obvious or not. Was hoping someone that has actually done this would chime in.
  17. #57
    08-13-2008
    Waterbury, CT
    3,331
    so i adventured into doing this and is seems way more pins need to change than this. doing it on a 96. all the injectors wiring was right and the tach signal it just seems like more pins are off.
    2014 Lancer Evo GSR
  18. #58
    08-13-2008
    Waterbury, CT
    3,331
    False alarm. I did not take the time to investigate the numbering of the 96 connectors, but now that I have I would like to verify this works for all 96 7Gs just the numbering in the factory service manuals is different but you don't have to worry about it as it does not matter
    2014 Lancer Evo GSR
  19. #59
    TGC Regular eclipsh's Avatar
    09-06-2008
    SW Colorado, USA @ 7600 ft
    533
    Here are the 7gb diagrams and pin voltages.
    If I could upload files of any size to this site I'd include a 2GB to 7GB wiring comparison with swapped pins highlighted.
