Great looking car, and way to go different on the swap. How many years people have been talking about it, and than here you are. Sweeeet!
*update
MMCS is working but forgot to put the bootable CD-ROM :
Some people demand a picture of engine bay because previous picture is too small, so I took more picture of bit higher quality, Maybe in near future I gonna use smaller battery and re-placing the wiring again to save some space. I should had have it cleaned before taking pictures though
Awesome Galant!
Looks weird seeing the USDM PFL tails on there. lol but digging the engine swap, kudos on that. I just love the look of 50/50 tails in general, I guess that's why find the USDM tails bland.
Awesome. It's crazy seeing the engine from my 3000gt vr4 stuffed in a 8g like I used to have. Looks great though. I wouldn't mind doing that some day. Did you use the gto rear differential?
So I'm assuming you have custom axles made with the transmission side GTO and spindle arm side Galant? But what did you use in the rear, Evo or Galant VR4 spindle arms?
Looks awesome. Why the 450cc injectors, do you have the 13G turbos instead of the 9B's? If you need help with that engine check out 3SGTO or 3si.org
I do want 1000cc injector but they're expensive and I need 6 instead of 4 so I just buy 450cc, at least they're better than stock injector
Mine are 9b, 13g are from europe version and sometimes can be found at japan since it's popular upgrade
Btw as you can see my galant is RHD and swap using JDM 6G72TT (RHD) so I dunno how hard for u to do this swap if yours is LHD
What psi of boost are you running since you have the 450cc injectors?
Parts below is based from states where they're available (ALL OF THEM ARE STOCK PART FROM GALANT !!!)
- Separated Headlamp and Turning lamp models from Galant V6 ==> Indonesia
- Set of Black Doorcards (including door handle, window switch and bolt cover) from Galant VR4 COTY edition ==> Japan
- 260 km/h M/T Hi Vis Dash model from Galant V6 Avance ==> German
- Black Leather Powered Seat from Galant VRM ==> Hong Kong
- MMCS system FL version from Galant VR4 FL ==> Japan
- Rear Lamp PFL USDM version from Galant GTZ PFL ==> USA
- Hood from Galant VR4 FL ==> Japan
- Trunk from Galant VR4 PFL ==> Japan
- Front, Side and Rear bumper from Galant V6 ==> Indonesia
- Grill from Galant VR4 PFL ==> Japan
- Black Nardi Steering Wheel from Galant VR4 ==> Japan
- Strut Bar from Galant VR4 ==> Japan
- Set of Black Dashboards (including glove box) from Galant VR4 ==> Japan
- Black Consolebox from Galant VR4 ==> Japan
- Boot Carpet / Velvet Cover ==> German
- Set of Carbon Center Console (MMCS version) from Galant VR4 ==> Japan
- MMCS system from Galant VR4 ==> Japan
anything I miss ?
You should be able to go higher with those 450's. The 9B's handle more boost but they drop off before redline. Theres a guy here in the US that holds the fastest 1/4 mile times with 9B's. Check the videos at the bottom.
http://www.streettunedmotorsports.co...in_stealth.htm
*update picture of My Galant, Very dirty after few runs on Highway
sold my car, update the picture for the last time at first post
I will miss it though
